Old Fri, May 1st, 2009, 11:06 AM
Pegasus doesn't like 64-bit Vista at all. You CAN make Pegasus work on 32-bit Vista and the procedure is in the Pegasus manual which you can download from PHP's website. If your laptop is Windows XP, Pegasus WILL run on it.
Thanks for looking out for me Lars, but I think I'm OK here. I'm pretty sure he must have the older hardware in his Gryphon, but with a firmware update, it should recognize all the hex codes in the 2004-2008 trucks.
So its the "firmware" that recognizes the pcm hex codes. I just had a bad assumption that it was something else. As long as the firmware is up to date then all is well.
