Old Mon, May 4th, 2009, 03:27 AM
Sburn Sburn is offline
Thanks for updating us mmandley. I DO want to correct one thing you said though. The Gryphon needs 12+ volts during programming, not 18V.
Hope you get your unit back soon.
Both you and mmandley correct about both 12 and 18 volts being needed. Ford uses an 18V signal on one of the DLC connector pins to initiate programming:
"FEPS: Flash EEPROM Programming Signal. 18 volt DC signal sent by the scan tool to initiate PCM reprogramming."
Since there's only a nominal 12V from the battery, I would assume that Gryphons and the like have a DC-DC converter to up 12V to 18V for that one pin during PCM programming.
