Old Mon, May 11th, 2009, 01:26 PM
Cool! Glad it worked! Just so you'll know, I did something like that once. Disconnected the battery with the Gryphon connected, then reconnected the battery and was horrified when I saw the Gryphon's screen as I turned the ignition on. But then I remembered that disconnecting the battery is sort of like unplugging the Gryphon. The ignition has to be on before you plug it back in!
After a while, we all get smart enough to figure everything out. :o
