Old Sun, May 24th, 2009, 08:07 AM
My first test run was to the grocery store. I did not go to the local one I went to the grocery store a little further away in Sioux falls. Had the butterflies in my stomach ever since I loaded the tunes. Well me and the little girl were off to the store, she had to try out her new booster seat.
PID'S I had on:
Cht
Speed
Volts
Comm gear
Just my luck! We get to follow slowa$$ Sunday drivers out to the interstate. I did feel something though. Eventhough they were driving slow, why did it seem I was going fast? Wierd? Turned the gps on and confirmed the feeling. Needle was at a +5 of the gps under 40 mph and +8 overthat. Got the grocery list out and wrote #1 adjustment tire size. The big test was my favorite double left hand turn to get on the interstate. Yes I was first up on the inside lane. Waiting patiently for the stop light to turn green. Told the little girl "hold on!".
Then it happened the light turned green and we were off! I was being cautious but yet aggresive due to the wet concrete. Went into the corner doing a power slide drift. Hung on to it and maintained it 3/4 of the way up the ramp. By the time I hit the entrance I was doing about 85mph with about my foot into it only a 1/4 to 1/3 of a peddle. My little girl kept repeating "again dad!" I said "that once was enough". Other than that little bit of fun I found the tune quite enjoyable. With new found passing power, I am happy so far.
One concern their is a little tc lock hiccup. It happens when I was going 40-45 in forth. Let the foot out of it slow up a few and ease back into it, the tc acts confused. It's like you nudged it and all of the sudden it woke quickly not gradually.
Redid ts to 2480 that works out to 6.3% squish
2470=7%
2498=5%
Weird the ph was at 2465?!
The other thing I noticed is the cht running 1-2 degrees warmer? At 80 mph at 71 degrees cht was at 209-210.
I love the shifts. I did not play with the firmness. Why do you have to?
With the ud pulleys I know the idle needs a bump she's running at 12.8 when at a stop in d with alot on.
