Old Fri, March 27th, 2009, 07:07 PM
mmandley's Avatar
mmandley mmandley is offline
Default Help my Gryphon does NOT work
So i got my Gryphon today and i was all excited, i read the book with it front to back over a coffee of course.
I went and installed it in my truck and turned the key on. Then plugged the tuner in and it powered up.
got my Hex code. TEJF1Q6
Set my screen up like i like it then went to Menu
Select performance
I selected 2 87 Tow tune
Turned the key off.
Turned the key on when prompted.
D2 error. Truck wont accept info from the tuner.
I retried several times and tried all three tunes and always got the same D2 error. I went into Tech Support and did a communication test and it passed.
Then i redid all the setting and started the truck up and drove it around and the display works and i get all the readings im asking for but it wont load any tune at all.
Last edited by Acidanthris; Wed, May 6th, 2009 at 06:41 PM. Reason: Customer doesn't need help anymore! :D
Old Fri, March 27th, 2009, 07:26 PM
OneTomcat's Avatar
OneTomcat OneTomcat is offline
PHP Cheerleading Section
OneTomcat is on a distinguished road
When I first got mine it seems to me it wouldn't load tunes as well. If I remember correctly I hooled it up to my laptop with the Pegasus software, did an update with the Gryphon update manager and all was well. I can't remember the code it gave me but it may have been the same as yours. Worth a shot.
I see Jack is online..... he may be able to help more.
Never argue with an idiot. He'll drag you down to his level and then beat you with experience!!!
'05 F150 FX4 SCAB
K&N FIPK
Magellan Navigation System
Full Boar Performance SIDO exhaust
Gryphon PHP Programmer w/ custom tunes
4UCam wireless backup cam
Old Fri, March 27th, 2009, 07:48 PM
mmandley's Avatar
Alright thanks ill try that tomorrow or something with my laptop. I assume the software you mention the Pegasus is available online for download? Ive herd everyone talking about it but haven't seen a site to get it from yet.
Old Fri, March 27th, 2009, 08:17 PM
OneTomcat's Avatar
Here ya go....download is here as well as step-by-step how-to. Hope this helps.
http://dygytalworld.ehost-services13...read.php?t=196
If you are running Vista you may have to disable your user account control as Vista and Pegasus don't play well together.
'05 F150 FX4 SCAB
K&N FIPK
Old Fri, March 27th, 2009, 09:31 PM
mmandley's Avatar
Ok thanks a lot. i got the software downloaded and working. Have to see if it fixes the problem. Im not to optimistic since all it says is the lastest version are already installed and any updates i try to the firmware or calibrations fail talking about server down issues.
Im guessing im getting those errors because its after 9pm eastern and there office is closed. Maybe they wont let you update after there normal business hours
Old Fri, March 27th, 2009, 09:41 PM
OneTomcat's Avatar
Won't hurt to try it but it may be something that Bill will have to walk you thru when he gets back. I suspect it isn't anything too serious and you will b e up in no time.
'05 F150 FX4 SCAB
K&N FIPK
