Old Mon, May 25th, 2009, 01:46 PM
04FX4 04FX4 is offline
Thermostat ?
Ok so what thermostat are you all running? I am running the stock 195 ,and now with summer and pulling a trailer it seems that the 195 may be to high and was thinking of going to a 180. Any body have any pros or cons to this before I do this. Will it affect my gryphon and custom tunes??
Old Mon, May 25th, 2009, 03:13 PM
Sburn Sburn is offline
Keep the stock temperature thermostat. Running too low of a temperature will make the engine computer think that the engine has never warmed up (>170 degrees) and the computer will try to compensate by keeping the mixture on the rich side.
If you really are running too hot, there's another problem beside the thermostat temperature.
Jack may chime in here and proabably has some good advice, since he tows a trailer in Arizona.
Old Mon, May 25th, 2009, 04:16 PM
I'll chime in all right. Yep, it's hot in Arizona and I've kept the stock thermostat in, basically, for the reason Sburn gave you.
The whole point of the thermostat is somewhat misunderstood by many. First, it's there to warm your engine up quickly. Coolant won't circulate until it opens, so the block get warm fast. Then, when it DOES open, it does so near the optimum operating temperature of the engine. It opens part way at first, and becomes fully open a bit later. At this point, your engine's temperature is maintained by the balanced design of radiator area, fan velocity, coolant quantity and chemical properties. The engine will not really overheat if things are designed and maintained properly unless you run the engine at very high rpms, pulling a heavy load, and at a slow driving speed in very hot ambient temperatures. If you get into colder conditions, the thermostat will begin to close to keep the engine in the ideal heat range.
If you use a colder thermostat, it will open too soon. With a good cooling system, the engine will stay between 180 and 200 for too long. However, if it was going to overheat with the stock thermostat, it will do so with the colder one too (and probably just about as fast, once the coolant starts circulating). Once the thermostat is open, regardless of the temperature it opens, the rest of the cooling system controls temperature increase.
So really, what the thermostat is for is to put a "floor" on the operating temperature range. You want that floor to be around 195.
When I'm towing, I monitor the CHT (since there's no coolant temperature sensor). About the highest I've seen it get is 216 (under very heavy load). The failsafe CHT is 258, so you can see there's a lot of headroom. I should add that the 50-50 mix of antifreeze/water and the fact that your cooling system is pressurized, raises the boiling point of the coolant to somewhere close to the failsafe temperature too.
Old Mon, May 25th, 2009, 04:24 PM
Great job, Jack! You got that one nailed perfectly. You too, SBurn.
Old Mon, May 25th, 2009, 11:43 PM
Keep it "stock" @ 195 for optimum performance.
Old Wed, May 27th, 2009, 09:57 AM
BlackSTX's Avatar
BlackSTX BlackSTX is offline
Baconator
I've recently swapped mine out for a 180 degree stat, so far so good. I know part of the reasoning for the manufacturers going to higher temps is emissions, I just don't like running a vehicle that hot, though I know it's engineered for it. It's possible that in the winter I may want to swap back to a 195 depending on how well it defrosts the windows in winter; but for now I'm happy.
The question I have is this something that may allow me to advance my timing a degree of two since the head temps are now a bit lower and will this help prevent pre-ignition to any usable amount? I guess, from a programming stand point, is there a benefit to having changed this?
