Old Tue, June 16th, 2009, 08:16 PM
rogers250 rogers250 is offline
rogers250 is on a distinguished road
help please!
im ordering a phoenix chip right now and i cant find the PCM code. i found the connector and all but no sticker with code???? i did find a code on the connector itself,, f2vo or fzv0??? not sure if its a z or 2.. are either of those it?? its a 1996 ford f250 7.3
Old Tue, June 16th, 2009, 09:36 PM
Unfortunately, the alphanumeric numbers you listed are not valid.
It will be 3 letters and a number (similar to the second one you listed).
Where are you located (state wise....just wondering if you have a CA truck) and is it automatic or manual? That will limit your choices of PCM family considerably.
Old Tue, June 16th, 2009, 10:50 PM
i am actually located in indiana.. and its automatic.
Old Wed, June 17th, 2009, 08:26 AM
My GUESS would be that you have a DPC-202 family PCM in that truck. Don't go by what I am guessing, but if you get tuning for that truck, I bet that you will end up with a TDE1 calibration.
The only reason I can see for the PCM not having a sticker on the connector body is that it's possibly a reman. (aftermarket) PCM.
The older powerstrokes (up to 97) have a lot of access to get an inspection mirror down in the hole and look at the numbers.
Old Wed, June 17th, 2009, 11:36 PM
I answered your post in Powerstrokenation.
If the letters you found were in fact F7TF-?? then you have a DPC-202 PCM. At this point it doesn't matter what the box code is (TDE0/YBT1/etc.) because you have a DPC-202 PCM. Get a TDE1 chip and BE HAPPY!
