Old Sun, August 2nd, 2009, 01:18 PM
not you not you is offline
not you is on a distinguished road
Default adjusting timing
ok I was told that i can adjust the timing a little bit on 87 and 93 tunes . My question is when i go in to timing section it reads 000 now when i adjust it Im thinking i have to hit done and thats when it programs the pcm . Now after its done i go back to timing it reads 000 again is the timing set to what i set it at (1.0 ) or is it not working or is it working and there is no record of the new setting (1.0) on the programmer or do i just keep track of it (writing it down) or am I just doing it wrong. Also how do i set it back to the setting that came with the 93 tune . ok I think thats a start point thanks for the help Shawn
Old Sun, August 2nd, 2009, 03:20 PM
Skipping custom options will always revert back to the original tuned programs.
Now, when you go back into the custom options to make further changes, you need to scroll up click and do "Load Previous Settings" to reload the last changes you made in the custom options. Otherwise it starts with a clean slate on the options and you'll have to re-enter everything.
Old Sun, August 2nd, 2009, 04:13 PM
Ok i go into customs options and go to timing and set the timing to 1.0 hit enter and go to prevous setting and the timing is set to what i set it to ? then i go to done and thats being downloaded to the pcm or when i set the timing and put 1,0 in its already set ? now how do i know where the timing is at its still not coming up to where i set it at im lost .
Old Sun, August 2nd, 2009, 04:16 PM
I figured it out and got it to save seen a little difference on 1.0 should i bump it up more or keep it at 1.0 you suggested go up to 2.0 but i think i might be pushing it whats your opinion on that thanks Shawn
Old Sun, August 2nd, 2009, 08:32 PM
It's not the best recommendation, but you could push until you either hear a little pinging on hard acceleration or you don't feel any more power difference. On the dyno, the lack of power gain would be more readily apparent. As for the pinging, the knock sensor should pull timing out at the first sign of it but you should still hear a couple ticks before the PCM reacts. If you've hit this point, back off at least 1 degree, if not 2, and call it good. Remember, if you get poor quality fuel you may get pinging on a tune that would otherwise run fine.
Old Mon, August 3rd, 2009, 08:08 PM
THanks for the info but i am not going anymore if its not recommended its not for me . I will just keep it at 1.0 and see how it does i see a big improvement already driving back and fourth from work. thanks for the tech support i know your busy and Im thankful for the help Shawn
