Go Back   Power Hungry Performance Forum > Ford F-150, Expedition, Navigator, Blackwood, Mark-LT, SVT Lightning and H-D Editions (Disabled) > 2009 to 2014 F-150
2009 to 2014 F-150
3.5L, 3.7L, 4.6L, 5.0L, 5.4L, and 6.2L equipped F-150s.
Old Wed, December 30th, 2009, 05:40 PM
martinoledad's Avatar
martinoledad martinoledad is offline
martinoledad is on a distinguished road
Default does tow/haul=overdrive
i was just wondering if the Tow/haul button was the same thing as the overdrive button on the older models.
Old Wed, December 30th, 2009, 06:20 PM
shotgun's Avatar
shotgun shotgun is offline
Gryphon CTS
The best I can figure out it's also different shift points, lock up points, and shift delays. In short, it's a completely different shifting strategy. It also provides engine brakeing.
The manual provides a lot of good information.
Last edited by Power Hungry; Fri, January 1st, 2010 at 04:08 AM. Reason: We prefer not to break engines. ;)
Old Wed, December 30th, 2009, 06:42 PM
Good job Shotgun!
Ford has copied GM on this one. GM has been running a set up like this since 2003. At least they have on the HD gassers.
Old Wed, December 30th, 2009, 06:46 PM
shotgun's Avatar
Gryphon CTS
Even a blind squirrel finds a nut once in a while.
Do you think they change the AFR too (richer)?
Old Wed, December 30th, 2009, 07:45 PM
Holy Cow! What a great modification! Makes me ALMOST want to run right out and get a new truck! Then I think of the payments and....
But, it's clearly NOT the same thing as the overdrive button. That only locked out 4th gear. As far as I can tell, nothing else changed.
They could have easily set the A/F ratio a bit richer too, as long as they stayed within EPA guidelines.
And, shotgun, super research! Good on you!
Old Wed, December 30th, 2009, 08:11 PM
ok thanks for the info
so is the overdrive automatically on
Old Wed, December 30th, 2009, 11:31 PM
In GM's they don't.
Alls it boils down to is different shift strategies and torque management that are both electronically controlled.
