Old Wed, September 2nd, 2009, 04:13 PM
mkf350 mkf350 is offline
mkf350 is on a distinguished road
Default Where did YOU mount your 6 pos switch???
Just curious where everyone has mounted there 6 position switch, hopefully with pics but not necessary..
2002 F-250 CrewCab LB
AFE ProGuard 7 intake
4" Magnaflow ss exhaust with 4" downpipe
BTS Trans Valvebody
Dieselsite Adreneline HPOP
Garret GP38R turbo
PHP Phoenix FU
Old Wed, September 2nd, 2009, 04:28 PM
I put mine on the left side of the steering wheel centered under the headlight switch. It is very low profile and that is what I wanted.
I had to take the fuse block off it's mounts to run the switch wire and mount it back up when I was done but it was not that much work and I think it was worth it.
I will try to send a picture later
Joe
2003 4x4 F350 Super Duty Crew Cab Short Bed
4" Down pipe and exhaust, Wicked Wheel, Modified Exhaust Turbo Housing, Big Head Waste Gate Actuator, PML Transmission Pan, Factory Tech Valve Body, Autometer Gage Pod, PHP FU2 Chip
Old Wed, September 2nd, 2009, 04:54 PM
Peroni's Avatar
Peroni Peroni is offline
Hit n Miss
Peroni is on a distinguished road
I put mine here, very easy to reach and change w/o having to look away from the road.
the 1997 F-350 XLT 7.3L PSD 4x4 CC LB BTS E40D Manual Hubs 4.10 36000 miles when purchased 4/1/06. Mods - ISSPRO Performax gauges, Tymar intake, Tymar 3x4 DP to 4" ss exhaust, electric fuel, CCV mod, tru-cool 4739, Swamps 175/30% injectors, stage I Stealth pump, D66 turbo Spearco 6.0 cac, BDP live tuned tuned 442hp/860tq.
Old Wed, September 2nd, 2009, 07:00 PM
Big Bird Big Bird is offline
Big Bird is on a distinguished road
mine is hanging from the trailer brake controler, havn't gotten around to drilling the hole in the dash yet. Give me some time, it only took me 1 1/2 years to finally install my gauges in the truck...
Old Sun, September 6th, 2009, 10:08 PM
Orezona Orezona is offline
Orezona is on a distinguished road
Can't tell you. It is in stealth mode
Old Fri, December 18th, 2009, 06:10 PM
majek5's Avatar
majek5 majek5 is offline
Nothin' Stock
Between the headlight switch and the front/rear tank switch. Fits like a glove, and if you weren't lookin you would not see it.
