Old Fri, January 16th, 2009, 11:15 PM
th3godf4th3r th3godf4th3r is offline
th3godf4th3r is on a distinguished road
Default What if I add something
hey Corey or Bill,
I am thinking about adding the troyer performance (unless you have a better choice) E-fans and UD pulleys.
What would i need to do to get another custom tune(s) just re-order them?
2008 White Ford F-150 Lariat Supercrew 4x4 | PHP Gryphon w/ Custom Tunes | 18" XD Monster's | 33" BFG A/T | AS Leveling Kit | Brandmotion iPod Adapter | 6000k H.I.D Lights | Line-X Bedliner | Weathertech Floorliners| True Dual Magnaflow Exhaust| K&N Cold Air Intake| Troyer Performance UD Pulleys
Old Sat, January 17th, 2009, 02:58 PM
The only consideration for E-Fans and Pulleys is to raise the idle a little in order to handle the higher current draw from the fans and keep the alternator spinning fast enough to keep the charging system functional. You can handle that through the custom options on the programmer.
If you'd prefer, I can raise the idle in your files. Up to you.
Old Sat, January 17th, 2009, 05:48 PM
im really considering it for the performance and MPG gains
i mean i dont NEED them, but im still trying to squeek out more MPG
Old Sat, January 17th, 2009, 10:04 PM
The pulleys really help, especially on the highway. Not to mention that everything spinning slower increases the life of those components.
I'm still a little torn on the fans. I guess it depends just how much the stock fan comes on, how much low speed driving you do, etc. Keep in mind though that e-fans draw quite a bit of current which puts more load on the alternator which puts more load on the engine, so I'm still dubious of any significant gains in that respect. The one thing e-fans definitely do is help increase the service life of the water pump by eliminating the weight of the fan from the pump bearings.
Old Sun, January 18th, 2009, 02:11 AM
well you have been close enough to Seattle to know what its like.
never gets reallly THAT hot in the summer but a couple days will get to above 90 and probably a couple weeks with temps in the 80's.
winter we might get snow once, doesnt get very cold, usually low 40s to mid 50's
so i dont know if they would be used alot or not? people just say that they improve mpg
Old Sun, January 18th, 2009, 01:07 PM
Northern Supercrew's Avatar
Northern Supercrew Northern Supercrew is offline
working for parts.....
Northern Supercrew is on a distinguished road
anyone know where i can get some of those pullies? 2008 f150 5.4. i think Troyer has them, but any others? i like Bill's answer to them..i do mostly highway driving, so it sounds like they should help a bit. i had a set on my old f250, 5peed 460, 1990 and had a hard time with alternators. might have been the truck or the pullies. these newer trucks are so much improved, hopefully the'll react better to pullies.
2008 f150 supercrew, 5.4, 3.73 LSD, tonneau cover, 275-65-18 BFG's. Gryphon programmer. XLT with XTR package. Tinted heads and tails with 8000 HID's. 4300 in the fogs. Gott's Mod. Painted grill.
