Old Wed, January 6th, 2010, 12:52 AM
brc51m brc51m is offline
brc51m is on a distinguished road
Default Does my blockheater work?
I have only tried plugging it in twice but both times I didnt hear or see anything when I plugged it in or the morning after when I woke up. Is there any way to tell if it is working?
Old Wed, January 6th, 2010, 02:17 AM
You could try using a IR gun that you'd point at it.
Or an ohm meter to test to see if you have continuity throughout the circut, of course do this when it's unplugged.
Or the way I was taught>>plug it in wait 10 minutes then crawl under there to see if it's warm. Caution it maybe more than warm don't burn your hand.
Old Wed, January 6th, 2010, 03:39 AM
^^^ just slide under there and feel for warmth.
Old Wed, January 6th, 2010, 08:59 AM
DVOM (multimeter) on ohms scale across the two flat plug-in terminals....you're looking for 12-14 ohms.
Old Wed, January 6th, 2010, 06:14 PM
Ok so I left my block heater plugged in all day today and just went and started the truck and I am going to assume that it isnt working because there was nothing different upon startup. How do I go about fixing this?
Old Wed, January 6th, 2010, 06:39 PM
What are your symptoms?
What have you checked?
Old Mon, January 11th, 2010, 01:59 PM
ChuckD's Avatar
ChuckD ChuckD is offline
Duty, Honor, Country
Let me make sure I am reading this correct. You plugged your truck in and it was like that all day. You then started your truck but noticed nothing different when your truck started. The point of having a block heater is for cold weather. If your truck is starting just fine without it being plugged in, your glow plug circuit is working properly. You wont hear it working, its basically like the heating element in your hot water heater.
Chuck
1995 Mustang GT
2004 Explorer Limited
