Old Wed, April 7th, 2010, 12:40 PM
jrthomas15 jrthomas15 is offline
jrthomas
jrthomas15 is on a distinguished road
Question asking opinion on gears
I have a 2006 xlt 4x4 with 35's.my question is what do you guys think about changing gears. Is it worth it to change. I have 3.55s ls
-Jordan
2006 F-150 5.4 4x4
Old Wed, April 7th, 2010, 12:53 PM
Well, those gears with those tires make for a pretty slow accelerating truck (at any speed). If you want more acceleration, a higher gear ratio is certainly the way to get it. AND, if you tow much, I'd say you are badly undergeared, which probably puts more strain on your transmission.
BUT, you have a 4x4, which means you need to regear both the front and the rear. This is not cheap, but I don't have any figures to quote you. It would be less expensive to return to your OEM tire size, I think.
What were your OEM tires? We could use the gear ratio calculator to figure out a suitable replacement gearing to get you back to what you had at stock. And, the next size up from that would give even better pulling power probably.
Old Wed, April 7th, 2010, 01:48 PM
With the 35's I'd suggest 4.56 gears.
Here's a good site to get them from.
Auto Parts - Differentials. AMC,Chrysler,Dana Spicer,Ford,GM,Suzuki,Toyota,
Go with the Yukon brand.
You'll also have to an install kit for each differential.
Also contact a local drive line/gear shop to see how much they would charge for parts and labor or just labor.
Changing gears isn't for the amatures or novice weekend wrench turners.
Old Wed, April 7th, 2010, 07:50 PM
jrthomas
I'm pretty sure my stock tires were 275/70/18
would putting in 4.56s help out with gas mileage
-Jordan
2006 F-150 5.4 4x4
Old Wed, April 7th, 2010, 11:16 PM
Regearing is always a good option.
It definately will help get the truck going.
Be better for your tranny.
But at highway speeds you may or may not see improvements.
Old Thu, April 8th, 2010, 01:31 AM
On my old truck (F-150) I went up to a 4.56 from 3.55 when I put the 35's on. It was a night and day difference, truck was much more enjoyable and had all the power back. I used my truck for about everything, towing, DD, highway, ETC, and would not change my decision on gearing a bit.
Also since you are most likely going to be changing the carrier in the rear (to make room for the larger pinion) you might consider adding a locker or some type of limited slip. IIRC you can use the stock front carrier, but you will have to have to buy a special "notched" center pin if you go with the 4.56's or larger.
Old Thu, April 8th, 2010, 09:49 AM
jmt0645 jmt0645 is offline
semper fi
jmt0645 is on a distinguished road
i'm currently running 33's and just swapped from 3.55LS to 4.56LS and the difference is night and day. acceleration is amazing and city milage i gain 1-2 mpg as i'm not having to put my foot in it as much, hwy (65-70) stayed the same, but anything over that speed it drops off. check ebay for the parts, i got mine from AZRACEPLACE for 215 shipped (2wd), they have 4wd sets for around 450. labor to install at my local shop was only 375 and took 2-3 hours
