Old Tue, April 6th, 2010, 01:42 AM
crossent crossent is offline
crossent is on a distinguished road
Default Tunes for alt fuel (atf)
Has anyone done any tunes for this type of fuel to limit smoke at idle? I still would love to get this done. I tried to set up a live tune but it didn't work out . Coming to cali any time soon?
Mike
Old Tue, April 6th, 2010, 11:30 AM
What do you think Cody, something with slightly advanced SOI and maybe ICP in the idle and low RPM ranges?
Just out of curiosity what ratio of atf are you running?
Old Tue, April 6th, 2010, 01:31 PM
The thing about ATF is that it's going to add a bit of viscosity (thickness) to the diesel fuel. Probably not measurable, but temperature may have an affect on it. Secondly, the ATF is going to combust slower (slower flame speed) and likely add a bit of lag to the actual ignition point.
As far as the ratio goes (ATF to fuel), that will have everything to do with the efficiency of the engine. You're certainly not going to hurt anything by running factory or aftermarket tuning designed for fuel-only use. However, I agree that a smidgen of SOI increase may help. However......if you're running ATF tunes without ATF, you may run into some combustion noise and possible engine damage. But, like I said, a SMIDGEN of advance....probably not enough to matter actually.
Old Tue, April 20th, 2010, 11:17 PM
Sorry for the delay in responding, I've been busy at the shop.I have run 100% with no adverse affect in power or mileage. It just smokes in traffic. On the highway maybe a hint more black smoke. It sure runs quiet.I only put atf in one tank and use it when on the highway, but would like to use it more often if possible.
Mike
Old Tue, April 20th, 2010, 11:26 PM
I ran about 70% used motor oil in my '94 PS it smoked a lot at idle but ran good other wise, had more power, boost and EGT, but fowled a few injectors after 4-5K miles. The injector(s) were dumping fuel.
I ran this truck on waist veggi oil for a 150k mile before this and only had to replace one injector.
Jay 413-222-8286 I got hay for sale
'97 F350 CC, DRW, pickup, 7.3, E4OD, 2wd, 4.10, 405K
'00 F550 reg cab, 11' flatbed, 4x4, 7.3, 6637, 4R100 (soon to be a ZF6), 290k
'97 GMC 5500, getting a transplant, 3.36, sleeper, 350k
Abolish the Federal Reserve, They are the #1 problem.
www.prisonplanet.com
Old Wed, April 21st, 2010, 01:15 AM
We've done VO, WO, and TFO tuning, all with great success. The key is atomization and careful attention to SOI (timing) curves as these make all the difference in performance and efficiency.
There are a number of systems out there that piggy-back the stock fuel system and activate when the engine reaches a specific temperature. These are preferable as they help eliminate cold start issue that may occur when using alternate fuels. I don't have any specific information on these, but a few members run this type of setup and have been extremely happy with it.
I hope this helps.
Old Wed, April 21st, 2010, 01:23 AM
Bill, If I send you my 6 pos , could you come up with a few "atf" tunes for me? Unless you are coming to the west coast sometime soon. I would still love to host a live tune at the shop.
Mike
www.crossenterprises.com
Old Wed, April 21st, 2010, 02:28 AM
Mike,
I talked to Ryan a while back and he was supposed to get in touch with you about trying to set up another event out there. I would love to get something going Sept-Oct. Since I won't be going to SEMA this year, there certainly won't be any conflict.
Let me know what you think.
Old Wed, April 21st, 2010, 11:21 AM
muns53's Avatar
muns53 muns53 is offline
PHP Tuned and Vegistroked
Location: Highland, NY in Ulster County (Hudson Valley / Catskills Region)
muns53 is on a distinguished road
I have the Vegistroke V3 (automated, heated parallel fuel system) on my Excursion and custom VO tunes from Bill in my Gryphon. I'm very, very happy with this setup. The system uses hot engine coolant to pre-heat the alternative fuel, which thins it out for proper spray pattern and full combustion. It also keeps air out of the fuel lines. The automation feature ensures adequate purge of the alternative fuel every single shut-down, so that the next start is always done on diesel. Also, if the alternative fuel tank runs out or the filter plugs or pump quits, it automatically reverts to diesel with no interruption in the engine running.
I believe ATF's viscosity is closer to diesel than cold veg oil or cold motor oil and I've read on various forums that people run it in blends with diesel to fuel Powerstrokes without a lot of issues. With veg oil, if it isn't pre-heated to at least 160*F before it hits the injectors of a warmed motor, carbon will build up and eventually foul the injectors, cylinders, etc. Also, as I understand it, a cold motor has some amount of fuel blow-by and causes the fuel to mix in with the crankcase oil. Not a huge problem with diesel fuel if oil changes are regular, but definitely a problem with veg oil. The crank shaft slapping around in a mixture of veg oil and motor oil will cause a mayonaise-like substance to form in the engine and will quickly toast it. I have no idea whether or not this is a problem with ATF or with mixing synthetics and petroleum-based oils together, etc.
With your current approach, starting on diesel in one tank and switching to ATF in the other when the engine's warm, you're probably avoiding the majority of the cold-start, blow-by issues. But I'm no expert on ATF and I don't know if burning cold ATF will cause injector problems over time.
I apologize for my commentary if it was unwanted and/or unnecessary. In any case, Bill is all over the tuning modifications and I've been running his custom VO tunes for about a year now as happy as a clam.
www.VibrantLED.com -- '02 7.3L Excursion Limited ~135Kmi total; ~50Kmi on WVO
Vegistroke V3 (installed 4/09); HIH, Aux Pump, FPHE (added 11/10); WVO Designs CF
PHP Gryphon; 6637 intake; 4" exhaust; Terminator HPOP; Tru-Cool; Evans NPG+; other goodies...
  #10
Old Wed, April 21st, 2010, 11:46 AM
Eric,
You input is absolutely appreciated! The more people know about what options are available, the better.
Big Oil (no, not the twin HPOP setups) has had a stranglehold on the diesel industry for way to long. There is absolutely no good reason for the price of diesel being higher than gasoline other than the damn fuel companies being greedy. I say screw 'em all and burn any waste oil you can get your hands on.
Any information or links you can provide for your oil system would be greatly appreciated.
