Old Thu, July 1st, 2010, 09:43 PM
sgg's Avatar
sgg sgg is offline
sgg is on a distinguished road
Default check engine light
Still love my tunes! But I'm curious about one thing... If I really romp on it in 80 DD or 100 Performance, the check engine light comes on. After I shut it off and restart it, the light is gone. I've only done this about 5 times since I installed the chip, but when it happened today, the truck also idled rough. Almost like it was skipping. I shut it off and restarted and everything was back to normal. I don't have access to a code reader. Just wondered if this has happened before with anyone, and if it may be serious.
Stacey G
95 F350 CC dually, 7.3l, auto, DIY intake, Rosewood Stage 1 injectors, 3" DP, 4" exhaust (no cat), EGT & boost gauges, 4.10 gears, Phoenix chip w/ 65hp Tow, 80hp DD and 100hp Performance
Old Fri, July 2nd, 2010, 07:43 AM
cj45lc cj45lc is offline
Mine does that also & Cody told me it's the HPOP not keeping up with the oil to the injectors. Was told it was not to worry about & my SES goes out a couple miles down the road.
Old Fri, July 2nd, 2010, 09:37 AM
Nothing serious. As CJ pointed out, it's simply due to the HPOP not being able to keep up with demand. The rough idle afterward is usually due to a slow-responding injection pressure regulator (IPR) valve.
Old Sat, July 3rd, 2010, 12:01 AM
sgg's Avatar
sgg sgg is offline
Thanks, guys. I kinda thought it was something like that. Just wanted to be sure. It's really amazing how quick 4 tons of steel can be! Hope to get it on the dragstrip one day, and on the dyno to see some real numbers!
Stacey G
