Old Sun, August 29th, 2010, 06:56 PM
edge186 edge186 is offline
edge186 is on a distinguished road
Default PMT2 hex code question
I was looking at the 7.3L box and hex code list and see that for a PMT2 i need files that have the code VRAA7S5
when i pull up the list of available calibrations for my chip there are only 4 tunes with this code.
0HP STOCK
65HP TOWING
80HP DAILY DRIVER
100HP PERFORMANCE
the other available tunes are code VRAA6S3 which are for a PMT1. does it matter if i use these tunes? will my pcm or truck be harmed if i do?
Old Sun, August 29th, 2010, 07:38 PM
You can use the PMT1 tunes, they will work fine in your PMT2.
Old Sun, August 29th, 2010, 07:57 PM
thanks man. I reburned it just a few minutes ago with two of the VRAA7S5 tunes and four of the VRAA6S3 tunes and had an issue with the truck dieing when i switched between the different tunes.
Im reburning it now with all VRAA6S3 tunes and hopefully it solves the problem. hope i didn't screw something up
Old Mon, August 30th, 2010, 09:17 AM
I talked with Bill a while back and he said that he was no longer going to offer more than PCM code with the FU packages....
You didn't hurt anything, but you CANNOT run different base strategies on a chip without experiencing exactly what you did. That's why the truck would stall or hiccup between tunes.
Old Mon, August 30th, 2010, 02:19 PM
once i reburned it with all the same base strategies it works fine again. i've never had this problem but then again i've never tried to burn it with two different codes.
thanks for the help.
