Old Tue, June 21st, 2011, 09:23 AM
widieseltech widieseltech is offline
widieseltech is on a distinguished road
Default 7.3 trans tuning
hey guys i have a 2000 f250 7.3 and i have a php cs tunes by bill and my question is, im rebuilding my transmission and making it stronger i have a tcs billet triple disc convertor, jw valve body, factory ford clutch kit, sonnax boost valve, line to lube pressure regulator valve, front lube/ drainback valve, tcc control sleeve, one piece rear case bushing and a spril snap ring. with this rebuild will i need to have my tunes revised/updated for the trans to work the way it should?
Old Tue, June 21st, 2011, 09:39 AM
The valve body will certainly cause you some harsh shifts with the tuning you have and the torque converter clutch apply will likely be a bit brutal too.
Old Tue, June 21st, 2011, 10:19 AM
Default tuning
so have an update will for sure be needed. i just hate to pay to have a update done for trans and then again in a few months for the single shot injectors, thats extra cash out the window.
Old Tue, June 21st, 2011, 10:30 AM
Robert6401's Avatar
Cody, I'm curious why he needs reburns when I didn't need them after getting a complete JW trans. Is that because John knew during the build what tunes I was running so he adjusted the line pressures to accomodate? Thanks, just trying to learn.
Bob-
Old Tue, June 21st, 2011, 10:38 AM
thats a very good question
Old Tue, June 21st, 2011, 01:59 PM
As I tell EVERYONE.
Run it and try it before you decide to pay for different tuning.
