Old Wed, February 25th, 2009, 12:29 AM
kingme03 kingme03 is offline
kingme03 is on a distinguished road
Default custom tune the custom tunes???
I was just curious if you can ,or if anyone does, change any settings after recieving your custom tunes. Is it still possible to change trans shift points or anything like the canned tunes it comes with.
Old Wed, February 25th, 2009, 10:48 AM
Sure you can. I did. Because I tend to drive like the grandfather that I am, I've reduced the shift points to try to get it into the higher gears as soon as possible. I've also increased the max speed, since I don't want it cutting out on me during a passing maneuver. And, I've found the value that seems to work perfectly for tire size, so I put that in too.
