Old Fri, April 1st, 2011, 12:15 PM
convertedman convertedman is offline
convertedman is on a distinguished road
Default New and have questions
I am looking into buying mymuddytruck's programmer. If we get this worked out, what is the next step I need to take as far as getting tunes? And I assume I shouldn't try to use it till I get new tunes for my truck?
thanks for the help.
Old Fri, April 1st, 2011, 03:01 PM
Not quite. Mymuddytruck should set his truck back to stock. and then he should return the programmer to a "canned" tune status before he sells it to you. If that is done, you will be able to use the programmer immediately with its canned tunes. I recommend you load the Level 2 tow tune and use it as a "daily driver" until you get custom tunes.
The next step though, once you get the programmer, plug it into your truck and copy down the "hex"/"calibration" code it will show, is to post that code in this forum, along with the unit's serial number and your name: http://forum.gopowerhungry.com/give-...-ecm-tcm-code/
Then, go to PHP's website and download and fill out the custom tune order form for the tunes you want.
Old Sat, April 2nd, 2011, 10:00 AM
Thanks JackandJanet for the info.
I am also pleased with the gotts mod variation you had posted on f150online. I have noticed some difference. thanks again.
