Old Mon, May 2nd, 2011, 02:14 PM
mcm7.3's Avatar
mcm7.3 mcm7.3 is offline
mcm7.3 is on a distinguished road
Default how much boost?
how much boost should i be expected to build on the 100hp performance tune? The most ive hit so far is 20lbs is this right?
Old Mon, May 2nd, 2011, 02:39 PM
I have mine set at 23-24 PSI max....
Any more than that and the turbocharger will start to hate life. Not to mention that you don't gain any power above that level with a stock turbo.
You SHOULD see more than 20 PSI with a stock turbocharger in the 100 HP program. Sounds to me like you need to start looking for a boost or drive pressure leak.
Old Mon, May 2nd, 2011, 02:41 PM
Sounds about right to me.
Remember, more boost does not always mean more power. You need to also look at exhaust back-pressure (via scan tool or manual gauge), the boost and back-pressure should maintain a 1:1 ratio for maximum power.
Old Mon, May 2nd, 2011, 02:52 PM
Well, looks like I was off a bit.....
Old Mon, May 2nd, 2011, 07:07 PM
mcm7.3's Avatar
So where would be the most common place to have a boost leak? I was thinking the boots could be loose, would this be a good place to start?
Old Mon, May 2nd, 2011, 09:48 PM
That's one place to look.
SHAWN
Old Tue, May 3rd, 2011, 08:48 AM
The o-ring on the compressor outlet, the hot-side boots, the intercooler end tank seals (if you have a plastic-tank intercooler), the cold-side boots, the boots at the intake plenums, etc.
Drive pressure leaks are really common where the turbine inlet pipes merge into the collector. It's a design flaw....nothing wrong with the truck. If you see soot where the pipes merge into the collector at the back side of the turbine housing, then plan on buying new pipes and donut seals.
