Old Thu, July 14th, 2011, 11:19 AM
Extreme Justice Extreme Justice is offline
Extreme Justice will become famous soon enough
Default Stock Tune and new tire Size Question
If i want to keep my Gryphon at Stock (0) setting how do I go about changing my tire size? or do I have to load "Tune" setting in order to change the tire size?
Thanks
Old Thu, July 14th, 2011, 12:05 PM
Thanks
If you have the newer CS/CTS programmer, you can change the Tire Size while leaving the vehicle's tune at stock. But, with the older monochrome Gryphon/Edge, you have to load a tune to do this.
Old Thu, July 14th, 2011, 02:52 PM
Ah, thanks Jack. I have and Edge, that I got converted by Bill in March of 2009 with Custom Tunes, and I just changed my tires to 305/55/20's from the stock 275/55/20's. I reset my gryphon about 1 year ago to stock, because i was getting some stuttering/hesitation occassionally. I've just gotten back onto the forum and noticed this seems to be an issue?
After over 2 years i connected my Gryphon to my computer today and it indicates there's updates, but when i tray too, it indicates to call PHP/vendor (or something like that and won't let me upgrade). Ive got the latest pegasus software installed. Any ideas?
Old Thu, July 14th, 2011, 03:19 PM
Jack, hopefully you can help me with this. I get this message when attempting to update my Edge/Gryphon.
Unable to locate Valid firmware file.
Please contact Powerhungry for further assistance.
Thanks
Old Thu, July 14th, 2011, 03:25 PM
When you get the update message, is it for Pegasus or is it for a Gryphon Update? (In other words, does it automatically pop up when you start Pegasus?) Just for reference, the latest version of Pegasus is v2.02.0944. The self-update feature in Pegasus does not work on Windows Vista or 7 due to security issues with those operating systems. The only solution is to uninstall, download the latest version from the website, and then reinstall. This new install changes the location of the files (moves them out of the "Program Files" folder) and resolves the self-update problems.
Anyway, there have been fixes to the hesitation and stuttering issue so if you have been experiencing that problem and haven't had that issue resolved, then we can take care of it and set up a new download.
On Edit:
Thanks
Could you please validate the serial number of the device from Pegasus? I am not finding the one you have in your CP.
Old Thu, July 14th, 2011, 03:46 PM
Bill, The Pegasus Software is using the latest. V2.02.0994. This is for the Gryphone update. I am using Windows 7 if that helps. I used the download from the PHP "SOFTWARE" site. No other installs of pegasus prior to this as I deleted the older versions before installing this version.
My Serial number is 1018875. I got updated and custom tunes loaded on May 2009.
I haven't looked at the stuttering issues till just now. sounds like what i have experienced. While sitting at stop lights, all of a sudden truck starts to stutter and run rough. didn't happen all the time, but enough that i just kept it at stock tune.
Not sure why not not the same setting in CP as I haven't changed anything.
Old Thu, July 14th, 2011, 04:02 PM
The serial number you have in the CP is 1018875, the same one you indicated. What's curious is that your serial number is not located on the server for a custom download so I don't know how you ever got your custom tunes. I have reset your download, so give it a try again and let me know.
Thanks.
