Go Back   Power Hungry Performance Forum > Ford F-150, Expedition, Navigator, Blackwood, Mark-LT, SVT Lightning and H-D Editions (Disabled) > 2009 to 2014 F-150
2009 to 2014 F-150
3.5L, 3.7L, 4.6L, 5.0L, 5.4L, and 6.2L equipped F-150s.
Old Thu, January 15th, 2009, 02:01 AM
2009 F-150 5.4L Preliminary Dyno Results!
Hey all...
Finally got back from Utah and needless to say, I AM EXCITED!
The new 2009 F-150 is running awesome and actually looks to be making a bit more power than the earlier 2004 to 2008 versions.
From what we've found so far, the only major difference under the hood is that the air filter housing has been relocated directly behind the driver's headlight and now uses a LARGE 12" x 12" pleated panel filter. This is definitely helping airflow.
As you well know, the new platform sports a new 6-speed automatic transmission which now has its own controller which is separate from the ECM. The ECM itself has been updated to a new, faster processor as well. Fortunately, the tuning is quite similar and we were able to get the base tuning done without any difficulty. Here are the preliminary results:
Test Conditions:
  • Vehicle - 2009 F-150
  • Engine - 5.4L
  • Transmission - 6-Speed Automatic
  • Gear - 3.73
  • Fuel - 85 Octane
  • Altitude - 4500 Feet
  • Ambient Temp - 76º F.
  • Barometric Pr. - 26.65 In. Hg.
Here are the dyno plots (Click on the images to view full size):
Horsepower Only
Torque Only
Horsepower and Torque
Horsepower, Torque and AFR
As you can see, the biggest gains were not on the top end but in the midrange... which is where you really need it! Notice that the stock AFR curve does not allow any WOT enrichment until about 4500 RPM! And you wonder why the trucks are always so sluggish off the line. The AFR stays right at 14.6:1 throughout most of the acceleration. Now add a Cold Air Intake which in most cases cause a slight to moderate lean condition and suddenly you have a situation that could be very detrimental to the engine.
I also included an additional dyno plot which show without question that removing the snorkel does, in fact, improve the performance of the vehicle, particularly above 3500 RPM. Based on calculations, removing the snorkel picked up 7.5 HP and 7.6 Ft./Lbs. These figures are very respectable, especially considering that we had already made a significant gain with tuning. Unfortunately, I didn't have time to retest the vehicle with the Performance calibration, but I would certainly expect to see similar improvements with the same modification.
Needless to say, we are really excited about the results, especially since we only ran 85 Octane fuel. We will be doing some (relatively) sea-level testing here in the next week or two along with 93 Octane fuel testing and fully expect to see even better results.
We'll keep everyone posted on the results as development progresses. Stay tuned...
Old Thu, January 15th, 2009, 08:31 PM
jfuller5 jfuller5 is offline
Location: Upstate New York , Cambridge . lake george area
jfuller5 will become famous soon enough
Default Impressed !!!!!!
Hey Bill, I am really impressed now that i can see the results on paper, are the 08 5.4 curves respective of these? Much smoother power and torque curves and also a huge gain in the midrange. Hats Off to your abilities . Jim
Old Thu, January 15th, 2009, 11:50 PM
Jim,
The 04 to 08 dyno curves are similar, although are a little bit lower than the '09. I'll try to see if I can dig up some of the older plots we did on the 2004 and 2006 trucks for comparison.
Old Fri, January 16th, 2009, 10:40 AM
Great information Bill! I too, would like to see the curves for 2004-2008 engines!
Old Tue, January 20th, 2009, 09:34 AM
Chris74's Avatar
Chris74 Chris74 is offline
AAA Rib Steak
I thought the 07-08's are a bit stronger than the 04 thru 06's? I know they have more free flowing exhaust manifolds!
08 FX4 CREW
K&N 63 series Intake
Magnaflow SI/DO exhaust
Custom tunes
Old Thu, January 22nd, 2009, 06:53 PM
oysterbone's Avatar
oysterbone oysterbone is offline
clambelly
oysterbone is on a distinguished road
where do i put my foot on it ? Hey, Bill & Corey do the kids need any coconuts?
Sometimes the light's all shinin' on me;
Other times I can barely see.
Lately it occurs to me What a long, strange trip it's been.
Last edited by oysterbone; Thu, January 22nd, 2009 at 06:56 PM. Reason: sentence structure; the
Old Mon, February 2nd, 2009, 07:58 PM
68galxl 68galxl is offline
68galxl is on a distinguished road
Default snorkel on 09
where is the snorkel on the 09? there is a air box mounted on the inner fender wall. its not like the 05 I had
Old Mon, February 2nd, 2009, 08:02 PM
The snorkel is attached to the airbox itself.
Remove the top of the airbox and the the filter. There are two 13mm bolts that hold the airbox in. Remove them. "Pop" the airbox up and pull away from the fender. The snorkel will come out with the airbox.
The whole thing takes about 5 minutes.
Old Thu, February 5th, 2009, 08:58 PM
Default snorkel
thanks for the info
Old Fri, May 15th, 2009, 04:24 AM
Tylus Tylus is offline
Noob
Tylus is on a distinguished road
sorry to revive an old thread...but I'm curious
I have a 2008 Epxy EL with 5.4 3v
From what I can tell, my Expy is almost 100% identical to the 09 F-150. The only obvious difference physically seems to be the radiator shroud.
I know the tuning is different since I have the 300 HP version, and they have the 310 HP version.
but since I have the same airbox...would I possibly see the gains you've posted if I remove my Snorkel? 7 HP for nothing would be awesome...and I'd love to see if it's possible
btw, any update if the Gryphon will be available for the 07+ Expy anytime soon?...or ever?
2008 Expedition EL
Limited - Black with some Chrome Accents
Tags
2009, dyno, f150, power, results, torque
