Old Fri, July 15th, 2011, 12:36 PM
eej711's Avatar
eej711 eej711 is offline
eej711 is on a distinguished road
Default Gryphon Data Streaming
I have done some data streaming with my gryphon and here is what it came up with dealing with the IECON. IECON is always on the left(y-axis) on these graphs.
Old Fri, July 15th, 2011, 01:05 PM
To make the graphs easier to see, right click over the dots, down to format data series, marker options, select built in and change to a dot that is size 2. It will clear it up a bunch.
Also, your axis is correct to have your dependent variable, IECON, on the Y axis.
Old Fri, July 15th, 2011, 02:21 PM
eej711's Avatar
Thanks, still learning about what to do.
Here are the new graphs
Old Fri, July 15th, 2011, 02:24 PM
I know how you feel. I got a new version of MS Excel after I lost my JMP and now I can't even get series like IECON into the Y axis because it has too many values. I'm surprised you were able to.
Old Fri, July 15th, 2011, 03:26 PM
eej711's Avatar
That's strange it won't let you. I clicked the column I wanted to plot with IECON first then clicked the IECON colum by holding ctrl to hilight both columns them made the graph.
