Old Thu, February 5th, 2009, 12:12 PM
nelstone74 nelstone74 is offline
nelstone74 is on a distinguished road
Default Tow settings
I was wondering what the recommended uses are for the various tow settings or how others are using them.
Ive seen other vendors list the different tow settings for different GCVW and yours are listed as HP gains
Old Fri, February 6th, 2009, 04:17 PM
As far as tow settings and how they're listed or named, regardless of who made the tune, it all boils down to how hard you want to push your truck and how high the EGTs are.
Typically, the tow settings boil down to transmission adjustments and other precautionary changes that help reduce EGT.
It's not really typical to find high-HP tow settings only because EGTs cause a big issue when making a lot of power. Besides, subjecting your drivetrain to 350 HP of continuous duty isn't the best for parts designed for 215.
The BEST tow tune is already installed on YOU....your right foot. Make the transmission shift better and watch the exhaust gas temperature.
Old Fri, February 6th, 2009, 05:08 PM
Cody-- Thanks for the input.
I guess now I am trying to figure out if I would need all three tow tunes or just two. I am still a trying to figure out how they are best used
Old Fri, February 6th, 2009, 05:33 PM
I ran DP-Tuner's 20HP Tow and 60HP Tow programs for a few years.
Pulling the horse trailer (6 horse steel) with 3 horses and grossing just over 20K lbs., the 60HP tune was almost too much when fighting a headwind before putting on a TN turbocharger. After that, I could stay on it for miles before I had to worry about EGT. Conversely, the 20HP tune fueled just about right...I could stay below 1200 deg. all day long. However, I would lose considerable speed when pulling a grade. No matter to me since I downshift to 3rd at 65 MPH anyway. Would 40HP be better? Who knows?
It depends a lot on the truck, too. An OBS like yours without an intercooler won't be able to take as much fuel without high EGT. On the other hand, your RPMs will be higher at any given road speed due to the 4.10 gears.
Rule of thumb is that the higher the RPM, the lower the EGT. Lugging will ALWAYS cause a high EGT problem. 65 MPH seems to be the magic number for my 3.73-geared SD for 4th gear. Any slower and it's going to get hot before it speeds up.....any higher and it's smooth sailing.
Old Fri, February 6th, 2009, 06:20 PM
huffer7.3 huffer7.3 is offline
huffer7.3 is on a distinguished road
I run 13k-15k daily in my fifth wheel. With a 40 tow tune from Bill, i have problem with enough power and my EGT's stay well below 1000. The only time I have to watch it is heavy loaded climbing on a hot summer day, 1200 sneeks up quick.
01 Crew Cab Dual Rear, 75gal Aux Tank
New Motor & New ATO Trans. W/E-Fan
Gear Vendors O/D, On-Board Air
Banks Intercooler, Brake, Exhaust, Guages(soon to be replaced)
AFE Intake, 38R BB Turbo, Turbo Master Waste Gate control
203 T-Stat Evans Coolant
Oil, Trans & Coolant Bypass Filters, Amsoil
6 Position Chip From Bill
Old Sat, March 21st, 2009, 01:02 AM
Default HP Tow recommendations
I have a follow up question for ya Bill
I wanted to get some more clarification on which Standard tunes are setup for towing and are the shift points and other transmission setting already set for towing or do we need to tweak them with Minotaur? any recommended weight limits for each one of the following? Not sure if the 80hp is a tow tune or not
25hp,
40hp,
65hp,
80hp,
100hp, 120hp, & 140hp ( not for towing?)
:thanks:
DJ
Back after many years.
2003 F250 CC LB 4x4 7.3PSD
Minotaur user.
