Old Sat, November 6th, 2021, 08:20 PM
Powerstroke Cowboy's Avatar
Powerstroke Cowboy Powerstroke Cowboy is offline
Big Sky State!!!!
Powerstroke Cowboy is on a distinguished road
Default Minotaur with quarterhorse Emulator
Hello all,
I just picked up a Quarterhorse emulator to use with the Minotaur software. I am really looking forward to "live" tuning my 7.3L Should make it a lot easier to get the idle set up right and clear up some of the haze in cold weather starting. Its a pain having to reburn the chip to test new tunes and see what the changes made perform like.
My question is. How do I get the Quarter horse to work? Do I need the 4-bank switch to use it for live tuning? The reason I ask is, I installed the QH on the J3 port just like a chip, I have the harness plugged in to the laptop I use for tuning. All is fine the engine will start and run in till I try to load the tune onto the QH. as soon as it loads the engine shuts off and will not start till I turn the QH off or hit the Stock button.
What am I doing wrong?
Thanks for the help!
David
Old Mon, November 8th, 2021, 02:17 PM
Normally, there shouldn't be any issues using the QuarterHorse. It's quite literally plug & play. What size binary file are you using? 224K? 256K? The QuarterHorse is going to require 256K files.
Let me know, or give us a shout and we can try to get this figured out for you.
Thanks!
Old Mon, November 8th, 2021, 09:52 PM
Big Sky State!!!!
Thanks!
Thank you for the response! I think you just pointed out the problem. My files are 224k not 256k. So I am sure that's the problem. Now to convert the files to 256k and try again.
Thanks for the tip Bill!! I did not know that.
2008 6.4L, CCLB, 4x4, BD tap shifter, Intake, Exhaust and tunes 316,000+ miles.
1997 7.3L, CCLB, 4x4, ZF6, 300/200, twin HPOP, 6.0 IC with 3.5 IC pipes, E-Fuel, HX55 Turbo, 240,000+ miles Tuning by me.
Minotaur user.
Old Wed, November 10th, 2021, 08:54 AM
No worries. If you have any other questions, let me know.
Old Wed, November 10th, 2021, 07:18 PM
Big Sky State!!!!
I got another question... I resized the files from 224kb to 256kb. As soon as the quarter horse downloads the file the engine shuts off and the check engine light comes on. As long as I keep the file loaded it will not start. But as soon as I click the "stock" button on the emulator, the check engine light goes out and it will start.
I have tried loading the file through the QH with the pickup off, key on and with the pickup running. The same thing happens both times.
Minotaur user.
Old Wed, November 10th, 2021, 07:21 PM
Can you PM me the file? I can take a look and see what's up. The file has to be in a specific format, and the bank ordering and padding are important.
