Old Wed, June 3rd, 2009, 09:31 AM
dsilva584's Avatar
dsilva584 dsilva584 is offline
PHP RULES!!!
dsilva584 is on a distinguished road
Default Limp home mode
Quick question.....I installed my custom tune in my programmer the other day and went to load it up in the truck. The tune installs fine and the truck runs fine but I have the limp home mode light on in my dash now....anyone have any clues?
Old Wed, June 3rd, 2009, 09:35 AM
I'm a bit confused - do you mean the check engine light is on? If you were in limp home mode, you would not be enjoying the way the truck runs.
If you go into the diagnostic menu, what code(s) is/are showing? And, just so we'll know, what year and engine displacement is your truck? (I see it's an f150).
Old Wed, June 3rd, 2009, 09:42 AM
dsilva584's Avatar
PHP RULES!!!
noo its not the check engine light its the little wrench light i believe its the limp home mode light
i have a 2006 f150 4.6.... truck runs fine just that the little light is on.
Old Wed, June 3rd, 2009, 09:44 AM
Do the diagnostics menu like Jack mentioned.
Put it back to stock see if it disappears?
Looking at your avatar picture you have a 04-08 f150.
Old Wed, June 3rd, 2009, 09:53 AM
dsilva584's Avatar
PHP RULES!!!
I will go put it back to stock during lunch today
the pic in my avatar is my 2001 f150 king ranch my once baby... now older kid that only gets turned on once a week and has only moved about 20 feet in the past year to cut the grass around it and wash bird poo off of it...in my eyes it looks like the truck in your avatar lol (wishful thinking) but it only has 9inches of lift and 38inch tires
Old Wed, June 3rd, 2009, 10:06 AM
At lunch before you put it back to stock see what codes are in the diagnostics. Then put it back to stock to see if it still happens.
1. Check and clean battery terminals if needed. Check cable ends.
2. May be starting to have issues with throttle body?
Picture in your avatar is small on the blackberry so I was just guessing?
Old Wed, June 3rd, 2009, 10:18 AM
dsilva584's Avatar
PHP RULES!!!
okay went out to the truck to check the diagnostics and came up with this code. I cleared the codes turned on the truck again and the same code came back. "Throttle petal position sensor / Switch f Circuit high"
Old Wed, June 3rd, 2009, 09:47 AM
dsilva584's Avatar
PHP RULES!!!
i was reading the manual and it said it would also show in your display that your truck is in "limp home mode" but it doesn't
Old Wed, June 3rd, 2009, 02:37 PM
dsilva584's Avatar
PHP RULES!!!
code is P2133...i went back to stock and the light went away. I drove around for about 20 min on the stock setting and the light never came on. I would like to take the time to thank PHP...my truck feels like I have a 1000lb anchor w/o the gryphon!!anyhow i couldn't take that pain very long and put my custom tune back on and the light came back on again. I am going to install one of the canned tunes to see if i still get the light.
ohh also thanks Corey for updating my login!!
Old Fri, June 5th, 2009, 03:47 AM
It's very unusual. I will say that 4.6L trucks are a lot more sensitive to programming and there are a few tweaks we can make that should fix the light.
I put an update on the server. Download it and let me know if the problem is resolved.
