Old Wed, August 12th, 2009, 08:38 PM
4x4billy 4x4billy is offline
4x4billy is on a distinguished road
Default ECM: not located!!!
where did it go!?!?!? lol
Greetings everyone... just got my gryphon in the mail, went to hook it up and where it should give me a Hex code it tells me that the ECM could not be located... i checked the connection with the OBD port and unhooked everything waited my 5 seconds, tried again and still the same thing. I'm sure i'm doing something wrong but I just cannot figure it out. I've read the book several times and while my comprehension level isn't the best, i feel like it's fairly simple.
hook gryphon to cable
turn key on
plug in to obdII port
acknowledge the caution/warning (no more of those)
and it does not find the ECM, or give me a hex code... what am i missing??
Old Wed, August 12th, 2009, 08:43 PM
1999RedXLT 1999RedXLT is offline
1999RedXLT is on a distinguished road
Default Are you getting instructions on the screen?
If I remember correctly, after I plugged mine in, it told me to turn the key off and then told me to turn it back on. I have plugged and unplugged mine several times and I think I've gotten that message. When I do I just unplug OBDII plug and plug it back in. That seems to work. Also, I've turned the switch off and back on.
Al
Old Wed, August 12th, 2009, 09:11 PM
Circuit Circuit is offline
Circuit is on a distinguished road
I have gotten that message when I plug it in without having the key on. I found mine works best if I have the truck on (not started) and then plug it in.
Hope this helps. Once you get it going you will never want to run stock again... except when you are teaching a younger person to drive...
2004 XLT SCAB / 4.6
Current: In bed lighting, K&N Drop-in, Gott's intake mod, Gryphon custom tuned
Future: Exhaust (next), UDP, eFans
Old Wed, August 12th, 2009, 09:19 PM
xlt, I turn the key on to the run position (radio plays, stuff works, etc) if thats what you mean?
circuit
i have not tried turning the key off/on with the programmer hooked up
Old Wed, August 12th, 2009, 09:32 PM
circuit
What Circuit was trying to tell you, 4x4billy, is that you MUST have the ignition key in the ON position (radio plays, stuff works, etc - but engine off) BEFORE you plug the Gryphon in. Is that the way things were when you connected it?
Old Wed, August 12th, 2009, 09:41 PM
What he said.
...and with that I will leave it in Jack's capable hands.
2004 XLT SCAB / 4.6
