Old Wed, January 13th, 2010, 11:53 AM
travisunderwood travisunderwood is offline
travisunderwood is on a distinguished road
Default EGT Probe Install
Any tips/tricks for installing the EGT probe in a 99 F250 Superduty with 7.3 engine? I see the instructions in the manual but I bit unclear where to drill the hole/etc
Thanks
Travis
Old Wed, January 13th, 2010, 08:11 PM
andrew's Avatar
andrew andrew is offline
andrew is on a distinguished road
Hey travis are you going post or pre turbo? Post is ok but better to be pre if you do it pre turbo look up from under your truck as if you were changing the oil. The exhaust manifold is just above and to the right or out side of the truck try to drill in the center of the manifold. Tap the hole and insert the probe and hook it up.
Old Wed, January 13th, 2010, 10:38 PM
^^^ Just tap into the driver side manifold, wherever you can get a strait shot with your drill will work.
Old Thu, January 14th, 2010, 10:47 AM
Yup pre-turbo. I will get under there and look. Had to order a tap in so I am a few days out. Thanks
Old Mon, January 18th, 2010, 01:03 AM
andrew's Avatar
good deal and good luck man
