Old Wed, December 30th, 2009, 01:28 AM
Default Boost
Thought I would start a new one,
What effects will boost have over fueling?
I see how the "low boost fuel" map works, but what else is changes with high or low boost pressures?
Old Fri, January 1st, 2010, 02:37 AM
Very little changes with boost, outside of the fuel limit vs. boost table. EBP, on the other hand, affects a few of the torque calculations.
Old Sat, January 2nd, 2010, 03:32 PM
roosterdiesel's Avatar
roosterdiesel roosterdiesel is offline
roosterdiesel is on a distinguished road
So all the people running EBP sensor eliminators and having a constant 25ish psi reading could be a problem?
I wish my computer with minotaur hadn't taken a dump. I have time to play and can't.
Antonio
'01 F-250 6spd 2wd Handshaker 7.3L PSD
Stealth Dual Hpops, AC Alliants
Headstuds and Forged rods balanced
DIY Regulated Return with Racor Filtration #54
GTP 38R out 4" exhaust
Southbend Con OFE to get it to the ground
Gauges...Boost, Pyro, Fuel Pressure and temp.,HPOil, EOT, Pre and Post CAC temps
I'm sure some other stuff I forgot!
Old Sat, January 2nd, 2010, 04:46 PM
I have had my EBP sensor off for quite a while now, the wire is still hooked up but sensor not plumbed into exhaust. Wonder if I should put that back?
Old Sun, January 3rd, 2010, 05:36 AM
If you turn the EBP sensor off in the program, the PCM uses MAP instead. That what the YEBP switch is for.
Old Fri, February 5th, 2010, 01:55 AM
Where the heck is the YEBP? And when I find it how do I turn it off?
