Old Thu, March 18th, 2010, 07:39 PM
bambo2888's Avatar
bambo2888 bambo2888 is offline
bambo2888 is on a distinguished road
Default Display/Screen Info. Intermittent
Hey guys,
I have been running my gryphon for about 4 months now, and have had the custom tunes for about 2 weeks.
I noticed today, at two seperate occasions, that the PIDs would... get stuck... randomly.
The screen was 100% visible and was divided into quarters, but the Inst. MPG and Speed PIDs were at 0, and the CHT and TFT were stuck at values too low to be possible at 25min in to the ride (74 and 113).
I pressed the menu button and the values instantly returned to the correct numbers.
04 Lariat 5.4 4x4
Gryphon Programmer custom tuned by Bill at PHP ~ 325/60/18 Terra Grapplers ~ K&N Cold Air ~ 2.5 HBS Level ~ Skyjacker Shocks ~ SI/DO Flowmaster 40 w/ deleted rear cats ~ 8000k HID headlights and foglights ~ Blacked out tails ~ Hardwired STI Driver ~ Rockford Fosgate Amp, 10" Sub, w/ Infinity References
BLACKED OUT TAILS FOR SALE!!
Old Fri, March 19th, 2010, 12:27 AM
Use the battery voltage pid to see what the voltage is doing.
These things start to do funny things before the battery goes.
Old Fri, March 19th, 2010, 11:32 AM
bambo2888's Avatar
Nope, battery seems fine. 14. running, and 11. or so cranking.
04 Lariat 5.4 4x4
Old Fri, March 19th, 2010, 08:02 PM
bambo2888's Avatar
any ideas? problem is still intermittent!
04 Lariat 5.4 4x4
Old Fri, March 19th, 2010, 08:48 PM
you might have a loose connection somewhere. Probably on the lower end of the cable where it plugs into the OBDII port.
Old Fri, March 19th, 2010, 11:04 PM
bambo2888's Avatar
seems to be a firm connection. likewise, every time that I noticed the frozen parameters, i reach down to confirm the connection between the obdII and the gryphon and nothing changes. the second I press MENU though, the parameter return to their correct values.
04 Lariat 5.4 4x4
