Old Tue, April 6th, 2010, 01:42 AM
crossent crossent is offline
crossent is on a distinguished road
Default Tunes for alt fuel (atf)
Has anyone done any tunes for this type of fuel to limit smoke at idle? I still would love to get this done. I tried to set up a live tune but it didn't work out . Coming to cali any time soon?
Mike
Old Tue, April 6th, 2010, 11:30 AM
What do you think Cody, something with slightly advanced SOI and maybe ICP in the idle and low RPM ranges?
Just out of curiosity what ratio of atf are you running?
Old Tue, April 6th, 2010, 01:31 PM
The thing about ATF is that it's going to add a bit of viscosity (thickness) to the diesel fuel. Probably not measurable, but temperature may have an affect on it. Secondly, the ATF is going to combust slower (slower flame speed) and likely add a bit of lag to the actual ignition point.
As far as the ratio goes (ATF to fuel), that will have everything to do with the efficiency of the engine. You're certainly not going to hurt anything by running factory or aftermarket tuning designed for fuel-only use. However, I agree that a smidgen of SOI increase may help. However......if you're running ATF tunes without ATF, you may run into some combustion noise and possible engine damage. But, like I said, a SMIDGEN of advance....probably not enough to matter actually.
Old Tue, April 20th, 2010, 11:17 PM
Sorry for the delay in responding, I've been busy at the shop.I have run 100% with no adverse affect in power or mileage. It just smokes in traffic. On the highway maybe a hint more black smoke. It sure runs quiet.I only put atf in one tank and use it when on the highway, but would like to use it more often if possible.
Mike
Old Tue, April 20th, 2010, 11:26 PM
I ran about 70% used motor oil in my '94 PS it smoked a lot at idle but ran good other wise, had more power, boost and EGT, but fowled a few injectors after 4-5K miles. The injector(s) were dumping fuel.
I ran this truck on waist veggi oil for a 150k mile before this and only had to replace one injector.
www.prisonplanet.com
Old Wed, April 21st, 2010, 01:15 AM
We've done VO, WO, and TFO tuning, all with great success. The key is atomization and careful attention to SOI (timing) curves as these make all the difference in performance and efficiency.
There are a number of systems out there that piggy-back the stock fuel system and activate when the engine reaches a specific temperature. These are preferable as they help eliminate cold start issue that may occur when using alternate fuels. I don't have any specific information on these, but a few members run this type of setup and have been extremely happy with it.
I hope this helps.
Old Wed, April 21st, 2010, 01:23 AM
Bill, If I send you my 6 pos , could you come up with a few "atf" tunes for me? Unless you are coming to the west coast sometime soon. I would still love to host a live tune at the shop.
Mike
www.crossenterprises.com
