| 2008 to 2010 6.4L Power Stroke Diesel (Disabled) 6.4L Power Stroke Diesel equipped Super Duty. |
Bill,
I recently had my tuner switched from the 5.4L to the 6.4L and I am curious about a few things... I ordered it with the off-road tunes (DPF delete) 1, what tunes should I be running while towing? (around 8000lbs) 2, do any of your tunes shut off the EGR? I want to run the block plates but not sure that I want to see the check engine light with those codes 3, Do you do custom tunes? I can upload from pegasus? Or is that gassers only? Also TCM programming? Wheres that at? I had to ask.
Sounds like you and I are in the same boat!!!!!
I forgot to ask the questions as well...
