Old Sat, August 14th, 2010, 07:08 PM
Default friend hooked on banks tc ?
My friend is hooked on banks products. I told him that I personal don't Like banks and thnk they rip people off. He is looking for a tc and is hooked on the banks tc. Can he get a better tc for his money like suncoast? He will be towing a 37 ft fifthwheel. He has a 02 7.3 f250. Also he is looking at the banks trans commander. I just want to help him get the best for his buck.
Thanks Eric
Old Sat, August 14th, 2010, 07:32 PM
I have been using a Banks TC for around 30k miles. It seems to be holding up well to 600ish hp, towing 14k around town twice a week, and a few 1000 mile trips (towing 14k) a year.
It is priced similar to other brand name converters so its not like you will be spending more on it.
Suncoast or Precision would be another option.
Tell him to get a PHP chip instead of the TransCommand<-----------.
Old Sat, August 14th, 2010, 09:06 PM
I'm going to print this to him. Can you explain why a pho chip is better than the trans command.
Old Sat, August 14th, 2010, 09:17 PM
cj45lc cj45lc is offline
You can tell him that I have a banks chip & trans command that he can get along with the fancy stickers banks wants you to put on your fenders! No BS
Old Tue, August 17th, 2010, 01:04 AM
My buddy says that the banks trans command is recommended for that tc. He is going to stick with that because its tested unless you can explain to him why a gryphon is better. He says he already has a programmer that programmed his pcm to a tow safe mode.
If you can prove to him why its better he will get that.
Old Tue, August 17th, 2010, 03:01 AM
If he already has a programmer that is "tow safe" then why would he need the TransCommand?
What does the TransCommand have to do with the TC?
IIRC the only thing that box does is jack with shift pressures. Otherwise it does nothing with shift timing/ strategy, torque reduction, TCC PWM, etc, etc, etc........... which have a great effect on transmission health.
I am not out to convince anyone not to use something I have no experience with, but if he is serious about towing, the money will be much better spent on a chip/ tuner that is designed and programmed specifically for that.
Just my 2 cents.
