Old Sat, July 24th, 2010, 01:13 AM
jdjam jdjam is offline
jdjam is on a distinguished road
Default Shifting
I've had my Gryphon in for over a month now and love it. The custom tunes are a step up from the evo. I used to run Level 2 with shifts up +4,+4, and +2 with the evo for about a year and a half. I put this on the form and I believe my gryphon is very similar. My question is about being on the interstate, passing somebody, and the tranny really hits hard because the truck goes from 4th(tq locked) to 2nd. I don't remember experiencing that before. If I don't stomp on it, 4th to 3rd is fine, but sometimes ya gotta be quick. Any ideas or just turn them down?
87 perf
93 perf
Old Sat, July 24th, 2010, 01:18 AM
What are the rpms the 2-4th gear shifts for WOT shift? I know I have been going all out on a race track and noticed I was going 70 in 2nd just before it shifted.
Old Sat, July 24th, 2010, 01:34 AM
Thanks for the quick reply. I don't remember off the top of my head. I didn't ask for anything special in that department. Thought I would mention that in case there are some standard numbers Bill uses. I just mentioned that I thought my exhaust was hurting low end and the tunes definitely took care of that. Don't know if that helps you at all or not. I will double check what the programmer says against actual rpms tomorrow. Everything feels great except the hard tranny hit when I go from cruising to trying to pass quickly if necessary.
Old Sat, July 24th, 2010, 08:52 AM
Your truck is doing what's be asked to do by your foot.
Old Sun, July 25th, 2010, 09:01 PM
WOT setings
1-2 5200rpm
2-3 5200rpm
3-4 5000rpm
Old Mon, July 26th, 2010, 08:01 AM
F150 Man 4Eva F150 Man 4Eva is offline
Hidden Valley
F150 Man 4Eva is on a distinguished road
Mine are set around 5000 as well. I usually stay on my custom tow, because it gets better gas mileage. I am pretty sure I have gone over 80mph in 2nd gear before.
Old Mon, July 26th, 2010, 10:51 AM
Originally Posted by jdjam View Post
WOT setings
1-2 5200rpm
2-3 5200rpm
3-4 5000rpm
I don't know that this will help your "hard" downshift from 4th to 2nd when passing, but I think your WOT shifts are all too high. Torque and HP are generally decreasing above 5000, so I'd recommend 1-2 and 2-3 at 5100 and drop the 3-4 shift down to 4600. Bill said once that the 3-4 shift is stressful on the transmission and he seems to prefer it down there.
Set the rev limit at 5500, because you start to get Torque Converter ballooning at 5400. However, the rev limit needs to be at least 400 above the highest WOT shift.
Finally, load your custom tunes without reloading any of your "previous settings" and check the WOT shifts and rev limit. I'd tend to stay pretty loose to what Bill put these at and my guess is, they will be quite close to the figures I just gave you.
I honestly don't know if the sudden downshift from 4th to 2nd is bad or good, but as 88racing said, the transmission is just doing what you're telling it to. My gut tells me the "lurch" is putting stress on things, so I tend to feed the gas in just a bit slower, giving me a transitional 4-3 downshift and then a 3-2 downshift (if the load and speed are right). I'm happy to have someone explain to me why this is not necessary if they feel this is the case.
