Old Thu, December 4th, 2008, 06:33 PM
Coke734 Coke734 is offline
Royale with Cheese
Coke734 is on a distinguished road
Default Gas Pedal Sensitivity
I have been using the Gryphon for several months now, first with Stage 1 then Stage 2, and it has been great. Mileage and performance gains are definitely noticeable and very welcome.
I have one problem, however, and that is with the extreme sensitivity of my gas pedal. I realize that the sensitivity has been increased to enable faster pedal response, but when I am driving down these Michigan roads and hitting potholes, I can't keep my foot perfectly still. This leads to my tachometer needle jumping up and down, my engine revving and idling, and my exhaust going from loud to quiet to loud over and over until either the potholes end (rarely) or I give up and coast until it's smooth.
I am not planning on cashing in my custom tune vouchers for another few months, after I order my intake so they can both be installed at the same time.
Is there a way for me to change the pedal sensitivity myself in the meantime, or would I need to wait until I can get custom tunes for this adjustment?
Old Thu, December 4th, 2008, 07:03 PM
I wonder if this is similar to my feeling that the truck is too eager to unlock the torque converter or come out of a higher gear range with increased throttle pressure? I posted on this in another thread here: http://dygytalworld.ehost-services13...hread.php?t=13
You might try lowering the TC unlock speeds or even the downshift speeds a bit in the gear ranges you are using when this happens. My limited testing of this so far seems to indicate I'm on the right track.
But, Bill can probably do something in the custom tune to reduce this "skittishness". It's not throttle sensitivity that's the issue here (and you wouldn't want to change that anyway), it's a transmission skittishness. I think it's set to unlock or downshift too quickly.
Old Thu, December 4th, 2008, 10:43 PM
What he's referring to is how aggressive of the throttle pedal is at light throttle. We used to get similar complaints from the diesel folks. This is a phenomena that is often associated with Drive-by-Wire systems. Since there is no direct relationship between the accelerator pedal (APP) and the throttle plate, there is a transfer map that takes the linear voltage from the pedal and applies a logarithmic curve to the output for the throttle actuator.
One of the more common modifications is to make the curve a little more aggressive to help improve throttle response. Once in a while, we get a little too aggressive in the light throttle portion and what you end up with is a "touchy" throttle.
This does NOT affect the shifting since those work on the actual voltage signal from the a APP. Those issues are usually caused by mis-adjusted shift strategies.
I'm looking into the throttle problem and will have an answer sometime in the morning.
Old Sat, December 13th, 2008, 12:57 PM
Royale with Cheese
Anything yet?
Old Sun, December 14th, 2008, 03:59 PM
Sorry about that. Just got back from a dyno event in Tennessee.
Give me a shout in the morning and we'll get your update online.
Old Mon, December 15th, 2008, 01:43 PM
Royale with Cheese
If it makes a difference, I went back to stock tune and the touchiness/sensitivity is still there but much, much less drastic. I have a vague recollection of adjusting a few values in the custom power programming settings, so I could have brought this upon myself.
Let me know how/where to get this update.
Old Fri, December 5th, 2008, 07:12 PM
Royale with Cheese
Thanks for the help, JackAndJanet, I have noticed this as well. The problem I'm talking about seems more like what Bill mentioned. The touchiness/sensitivity is most evident before the lock appears in the COMM GEAR display.
Please give us an update as soon as you have something, Bill, and thanks!
Old Sat, December 6th, 2008, 07:28 PM
Yup, Bill's explanation is far more on the mark than my feeble attempt, wasn't it? :o
But, I'm glad you notice the sort of "over aggressiveness" of a downshift or torque unlock when adding a little throttle to either speed up a bit or to maintain speed up a mild incline.
We drove back from Phoenix today in Janet's Toyota (4 cyl, 30mpg, easier to park) and were on a several mile long upwards incline on the interstate at 75mph and the car stayed happily in 4th gear overdrive all the way. I know the Ford would have been going in and out of an RPM shift between about 1900-2400 on this same stretch.
But, I haven't been able to test the Ford again on the same kind of incline since playing with TC unlock and lock points.
