| 2003 to 2007 6.0L Power Stroke Diesel 6.0L Power Stroke Diesel equipped Super Duty and Excursion. |
Hello to everyone in the Good 'Ol USA:
Jonathan "Cooter" Carlson here form the country of Afghanistan with a question on custom tuning for my 2004 Ford F350 6.0L Diesel (which is sadly back in the States ):1) Does the calibration use a exhaust pressure sensor feedback strategy? I have heard that later calibarations do not use EBP feedback in engine performance- which is more preferable? 2) Can my intake be adjusted? I am installing a 4in diameter intake and need to know if they increased surface area can be taken into account in the programming. 3) I am installing a custom made external oil cooler (Goodbye nasty Ford internal oil cooler!!); can the error code for more than a ten degree difference between oil temp and coolant temp be removed from custom calibrations? I've been told that if not the ECM will retard the motor from making higher levels of power. ![]() Thank you everyone who can shed some light on this; I am in the process of buying parts for the truck (Garrett POWERMAX turbo, 155CC injectors, custom made water/meth system). Just because I am deployed doesn't mean I can't enjoy my truck!! ![]() Thanks!! Jonathan |
I'll try to get Bill or Cody to answer this.
The 10 degree delta was added to the latest calibrations from ford, if you roll back you don't have to worry about it.
19 F-350 6.7 Auto 16 F-350 6.7 Auto 05 Excursion 6.0, Auto, PHP Atlas 40 FICM, ARP Studs VXBC6(truck PCM) 00 F-350 7.3, 12 Speed, PHP Gryphon, PHP hydra, DAC3 95 F-Superduty 7.3 DI, Auto, Mechanics Truck 94 F-Superduty 7.3 DI, 5 speed, Flatbed |
you may or may not have an inferred ep calibration the only way to know for sure is if you have access to a device that will read the ecms current calibration code.
out of curiousity is your 2004 truck an early or late 04 model? sounds like you are on the right path with your modifications, the powermax turbo and 155s will work well together. have you looked into an egr cooler delete or block off kit? it would be a good idea, esp with the modifications you are planning. |
