Old Wed, January 26th, 2011, 09:10 PM
Flats1 Flats1 is offline
Flats1 is on a distinguished road
Default Exhaust help
Ok I need some help with my truck. My cats on my 2005 4x4 f150 5.4 are clogged. I was wanting to buy a whole new exhaust kit from the manifolds back but nobody sells a kit like that. Does anybody know if there are aftermarket cats that would work with this truck? Also I was considering cutting the cats of since they are so expensive to replace has anybody done that with this truck? Was there any affects to the truck after doing so? I know there would be a check engine light but can i get my edge custom tuned by gryphon to take care of that? Thanks for any help.
Old Wed, January 26th, 2011, 09:30 PM
I cant for sure answer all your questions about your truck, but I would for sure check to see if it's legal in your area to run without cats... some areas of the country let you get away with it, but you will want to be sure in order to avoid any possible fines... ,
Also if you dont want to replace both cats, you can just replace 1 and have bill write you a tune to match.
I know there are places that sell manifolds, cats, and cat-back exhausts online, but IMHO I think that you might want to go to an exhaust place and see what they think, and see how much they charge.
Hope I helped
Old Wed, January 26th, 2011, 09:55 PM
jmwilso2 jmwilso2 is offline
I ordered the dynatech headers for my truck from Jegs performance online, I kept the stock cats in mine but they sell the same kit with a set of high flow cats also.
Joe
07 F150 4x4 Super Cab Long box. 5.4L, Gotts mod, Flex-a-lite Monster efan, Dynatech long tube headers, true dual exhaust with x pipe and Borla mufflers, and of course the Gryphon. Bushwhacker extend a fender flares, Tech tube wheel to wheel step bars, Piaa HID Shock Lamp moose spotting lights. Morimoto projector retrofit with 55W HIDs.
Old Thu, January 27th, 2011, 12:15 AM
hampsterzone's Avatar
Come Get Some
How do you know they are clogged? Summit Racing sells high flow cats that will work great for your truck. You can also remove them if your state or county doesn't do emissions testing. You will need 2 dummy O2 sensors that go behing your missing cats so you don't have a check engine light. You can find them online for $99 a piece. I would run 3" true dual exhaust w/ your choice of high flow mufflers, and of course have "The Mad Doctor" adjust your tunes.
2nd place is 1st's loser!
Old Thu, January 27th, 2011, 06:00 AM
I know the cats are clogged because I have been having trouble with my truck and finally had the time to check the cats and the one side it completly gone I actually poured out some of the cat onto the ground. No we dont have any emmision testing here. So what aftermarket cats will work for my truck? And were would the o2 sensor go?
Old Thu, January 27th, 2011, 09:43 AM
Come Get Some
Go to summitracing.com. Enter your info and you should be able to find which one. But I have talked to them and most of thier high flow cats will work as long as they match up on the pipe you have going in and coming out. I can't remember off the top of my head where you get the dummy sensors. Google "dummy O2 sensors" is how I found them. If you do replace your cats, there are 4 sensors. In the front of both cats and one being both cats. Your factory pipe should have places already there for easy install. Just make sure you have them put in after welding is done as not to burn them up! I hope this helps. Good luck my friend.
Old Fri, February 18th, 2011, 03:33 PM
Come Get Some
How did your truck act when the cat was clogged? Hesitation, jerky, and intake backfire? The reason I ask is my truck is not throwing codes by the check engine light flashed a 4 times. Ford said it could be clogged cats or a dirty Mass Air Flow Sensor. Or possibly the wrong spark plug from Auto Zone. Your feedback would be much appreciated.
Old Thu, February 24th, 2011, 07:27 PM
I have a little over 80k miles on the truck. 88Racing My injectors went out and I had to replace them. I did it my self but I called the dealer and asked if there was anykind of warrenty on the injectors and he said no. Do you have anymore info on that?
hampsterzone
my truck would not shift under full throttle you could hold it to the floor and it would not shift... But under normal driving it would shift fine. Also it would backfire and spark nock terrible. Also the passenger side exhaust the one that was clogged had hardley any air coming out of it....home this helps some oh and also bad gas milage.
