Old Fri, February 18th, 2011, 01:41 AM
wood4heat's Avatar
wood4heat wood4heat is offline
wood4heat is on a distinguished road
Default Which tunes for my needs?
I am planning to order a Gryphon CS sometime soon and am looking for some input as to which tunes to order. First a little background, I am using a 2003 7.3 that's also in for a 4" turbo back exhaust, an intake system, and an upgraded tranny cooler to pull a toy hauler weighing around 7,000lbs empty and 10,000lbs loaded. I'm in the PNW and practically can't get anywhere without crossing a mountain range or two.
I'll start with my question regarding the 65hp tow tune vs the 80hp tow tune. Specifically whats the reasoning behind the 7,500lb weight limit on the 80hp tune? Is it strictly an EGT thing, will the trans not take it or is there another reason?
Also it seems many people report better mileage with the higher hp tunes. would it then stand to reason the 80hp tune would get better mileage than the 65hp?
Last along that same line of thinking could the 100hp performance tune get better mileage than the 80hp daily driver if driven moderately?
I wasn't sure where to put this so feel free to move it if there is a more appropriate forum. Thanks for your input!
Last edited by wood4heat; Fri, February 18th, 2011 at 01:44 AM. Reason: wanted to add something
Old Fri, February 18th, 2011, 03:54 PM
jmt0645 jmt0645 is offline
semper fi
jmt0645 is on a distinguished road
yes its related to EGT, adding more power requires more fuel, which generates mor heat
not sure
my understanding is bill writes DD tunes for better mileage than PERF tunes on diesels
hope that helps
Old Sun, February 20th, 2011, 02:54 AM
wood4heat's Avatar
I think I'll stick with each of the tow tunes and the 80hp daily driver. Any of the performance tunes would probably just encourage me to tear up.
Thanks for the reply.
Old Sun, February 20th, 2011, 04:14 AM
"" means your tires and drive train of course...
Old Sun, February 20th, 2011, 12:25 PM
dpcrf450 dpcrf450 is offline
Semper FI
dpcrf450 is on a distinguished road
I am in the same situation as you in Calif and I chose the 40 and 65 hp tow tunes. I will let you know how they work when I get my CTS.
Old Sun, February 20th, 2011, 06:20 PM
wood4heat's Avatar
Yup!
Well that was a new one. I tried to reply with just a "yup!" and received a pop up message that my post was too short, it must be at least 5 characters. I didn't want to put all of this in here, I had to...
Old Tue, February 22nd, 2011, 03:53 PM
semper fi
some people might say this is because of government mind control!
