Old Tue, March 22nd, 2011, 11:56 AM
cowboy's Avatar
cowboy cowboy is offline
rough n ready
cowboy is on a distinguished road
Default What exactly is a gryphon upgrade.
So what exactly is a gryphon upgrade? Currently I'm a computer programmer, and have in the past was a chip based programmer, so that is why the curiosity.
I mean is it a new chip with your custom code, or do you just reflash the existing chip in the programmer with your code? I know some of it may be sensitive so a simple yes or no will do if you can't fully explain.
Now I have a stock evo. The only performance mod I've done right now is the Gotts mod with plans to add efans, underdrive pulleys, exhaust and others as time come. Is it worth it to wait for all that to be done or should I change the evo to the gryphon before hand?
I normally run 89, and and plan on doing some towing down the road, I was thinking 89 performance, and 93 tow tunes, what are your thoughts?
2004 FX4 5.4L 4x4
Tuff's Transformation
"Courage is being scared to death - and saddling up anyway."
Old Wed, March 23rd, 2011, 09:40 AM
It is taking a basic Edge unit, reprogramming it, recasing it in some situations and sending it back with the improved canned tunes, other improved functions and the ability to accept custom tunes.
If you have a '97-'03 and a monochrome Edge you can't upgrade. PHP no longer upgrades those programmers because of a cable issue.
The CS and CTS, however, can still be used on those trucks.
You can upgrade at any time and put your order in line for custom tunes.
Old Wed, March 23rd, 2011, 09:43 AM
cowboy's Avatar
rough n ready
cool thanks, I do plan on doing a true dual exhaust, so I'll wait till that is done, and then get the custom tuning.
2004 FX4 5.4L 4x4
Old Wed, March 23rd, 2011, 09:45 AM
How far down the road do you plan on doing it. Getting the exhaust done THEN ordering your tunes isn't a good idea because of the wait time. If you'll be doing them really soon then go ahead and order them.
Old Wed, March 23rd, 2011, 09:47 AM
cowboy's Avatar
rough n ready
hopefully by August I should have the exhaust done, I haven't exactly figured everything out for it other than I want true duals.
2004 FX4 5.4L 4x4
Old Thu, March 24th, 2011, 12:50 AM
Truduals can be done anytime......its when you put longtube headers on that custom tunes will be needed ....cat deletes....and or high flow cats...
Don't forget install a x pipe...
