Old Thu, May 10th, 2012, 10:46 AM
jallen3521's Avatar
jallen3521 jallen3521 is offline
Semper Fi
jallen3521 is on a distinguished road
Help Options
I have an Edge Evolution (Original one).
I would like to reprogram the ECM back to a perferred stradgy (currently ECM: VXAP2N2.HEX and PCM: TQAU0N3.HEX)
Also looking into FICM tune would like to go with Hercules or Atlas 80. I Tow a Travel Trailer that is 8,000lbs dry weight (up to 10,000lbs Fully loaded). Wondering if either of those are reccomended or if EGTs will be too high when towing?
Also I can do all of this through my Programer correct?
Old Fri, May 11th, 2012, 07:24 PM
Jeremy's Avatar
Jeremy Jeremy is offline
Spark Plug Inhibited
Yes your evolution can do all of those functions once its changed to a gryphon. However, I has to be changed between the rollback module and the ficm programer by Bill...remotely. It won't be both at the same time.
I'd recommend the Atlas 40 vs the A80 just because of the weight of your trailer. But thats just my preference.
19 F-350 6.7 Auto
16 F-350 6.7 Auto
Old Wed, May 16th, 2012, 09:53 PM
jallen3521's Avatar
Semper Fi
Well I just submitted my order form for the Atlas 40 and the PCM roll back.
I can't wait.
Planning on getting a custom tune too for the Evo.
Any known problems with the 140 Extreme tune on stock head bolts(Figure I will wait until they go to upgrade)?
2004 F250 6.0L S-Cab Long Bed, 4" exhaust, Edge Evo, Blue Spring, EGR Delete, PMM Coolant filter, Smoked LED lights in rear, Smoked cab lights, 3" Lift , 18" DC-2's with 275/70R18 Nitto Terra Grapplers, Warn Manual Hubs, Rhino Liner
Old Fri, May 18th, 2012, 02:45 PM
jallen3521's Avatar
Semper Fi
I was talking about the custom tune for my edge evolution not the FICM tune.
Old Tue, May 22nd, 2012, 10:15 PM
judgejustin judgejustin is offline
judgejustin is on a distinguished road
OK really confused. I thought the CTS could not program the ficm or rollback the ECM. At least that is what one of the moderators had told me here on the forum. I thought I was going to have to either buy a separate programmer or get a rented one from PHP.
So, let me get this straight. I can order the FICM reprogram, the ECM rollback and custom tunes all at the same time and use them with my CTS and no other hardware. All I have to do is coordinate with Bill about getting it changed between the FICM programmer and the ECM rollback. The whole time though it will run custom tunes as well?
Old Tue, May 22nd, 2012, 10:27 PM
jallen3521's Avatar
Semper Fi
From what bill told me was if I had one of the original evolution model #15002 or 15003 then that could be used for ECM roll back FICM tune or custom ECM tunes.
