Old Sat, July 14th, 2012, 06:54 AM
charlie9092000 charlie9092000 is offline
charlie9092000 is on a distinguished road
Default "tranny shudder" at 45-50 miles per hour
I am getting "tranny shudder" at 45-50 miles per hour when using 89 performance mode, it doesn’t do it when at stock or when the custom 89 tow tune is used.
I have 2005 5.4
The invoice # is 4469 invoice date is 5/4/2011
Hex RXCM5E4
Any help would be great .
Charlie
Old Sat, July 14th, 2012, 02:34 PM
If you have the monochrome gryphon try raising the torque converter lock/unlock points.
Old Mon, July 16th, 2012, 12:36 AM
He could do this with the CS/CTS platform too, Longshot.
Old Mon, July 16th, 2012, 06:56 AM
I have the monochrome gryphon , any suggestions on the values that I need to enter? Should I copy the values that the tow mode is using?
Old Mon, July 16th, 2012, 07:52 AM
In the custom tuning options you'll find torque converter lock points. These are speed and throttle based events that when the vehicle reaches the point the torque converter locks or unlocks. Your vehicle is currently sitting in a grey area where it can't make up its mind. Go to that setting in the custom options menu and raise both the locking point and the unlocking point by one and give it a drive. Keep raising it until the shudder goes away.
The tow tune will most likely show 0 for the locking/unlocking points because these settings are a change from the baseline.
Old Fri, August 10th, 2012, 04:28 PM
Default Thanks for your help
I raised both the locking point and the unlocking point by two and that fixed the issue.
