Old Wed, June 17th, 2009, 08:15 AM
Default Injector post for nine5flareside (moved)
I moved this question so it would be easier to find. It was posted in a non-related section and I thought it would be better served with its' own post.
Injectors, larger high pressure oil pump, and tunes to run them.
It shouldn't be too hard to lay down 350 RWHP with the right combination of parts, but 250 RWHP is about all you'll get with stock injectors and good tuning on an early PSD.
Originally Posted by nine5flareside
so ive got a 95 302 5.0 with 19lb injectors... if i go up to lets say 24lb injectors and proper maf sensor i will see better performance?
Old Wed, June 17th, 2009, 08:16 AM
Here's the deal with a gasser and larger injectors.....bear with me
The short answer is "no" and this is why.
A gasoline engine relies on a constant 12.5:1 (very rich) and 15.5:1 (very lean) with 14.7:1 being considered "stoichiometric" (perfect) air/fuel ratio to run. Air and fuel are both metered to always arrive at this number no matter the load, RPM, or temperature. Slightly richer mixtures are going to produce more power, run cooler, and occur under load. Leaner mixtures are going to be hotter, more prone to detonation, and occur under light loads (cruise).
One would think that putting larger injectors would get more fuel out and make more power. This is absolutely almost never the case because.........
The stock injectors will be able to deliver enough fuel to maintain the air/fuel ratio on an engine that has quite a few modifications without retuning the PCM to compensate. By compensate, I am referring to the fact that a "19 lb." injector will put out less fuel than a "24 lb." injector given the same fuel pressure, same injector on-time, and same firing frequency. To compensate for this, the PCM would have to be programmed to command the injectors on for far less time at idle and through the midrange. It is also very certain that with a near stock engine that the ENTIRE range of operation be "pulled-back" because there is simply too much fuel across the board.
You mentioned a MAF/injector combo. Ok. Well, that includes a MAF sensor that is calibrated to send a signal back to the PCM indicating that there is not as much load on the engine (not as much mass air flow through it) so the PCM automatically cuts back the injector on-time anyway. Can I ask what the point is? It's like giving a kid a Snickers bar and then getting mad that he starts eating it.
It's almost certainly something I wouldn't spend my money on.
Old Wed, June 17th, 2009, 11:16 AM
nine5flareside's Avatar
nine5flareside nine5flareside is offline
Crusty crab
nine5flareside is on a distinguished road
I figured as much and that is why I quoted you when you said "injectors", larger high pressure oil pump, and tunes to run them. From my understanding the guy really didnt have mods that required bigger injectors I just didnt understand why you put "injectors", larger high pressure oil pump, and tunes to run them" as things for him to upgrade.
Being that you know so much about injectors, when is a good time to upgrade your injectors. When you upgrade what parts exactly should you be looking into more fuel delivery?
Old Wed, June 17th, 2009, 02:36 PM
Because the original thread had to do with a Powerstroke diesel.....not a gasoline engine.....and higher-flowing injectors make a HUGE difference in power on a diesel. His main intent was figuring how much additional power he could make with his 96 Powerstroke and which tunes to get on his Phoenix. He needs a higher fuel rate than his stock injectors can give him to make much more than 60-80 additional rear wheel horsepower.
Being that you know so much about injectors, when is a good time to upgrade your injectors. When you upgrade what parts exactly should you be looking into more fuel delivery?Are we talking now about gasoline or diesel? Larger injector usage would be anytime you have the capability of making more horsepower than the original fuel injectors are capable of supplying like when using forced induction, nitrous oxide, or the capability to run substantially higher RPM. Horsepower is absolutely dependent on how much fuel you can burn. The more fuel you can burn in a given amount of time and at a given RPM, the more horsepower you'll make.
Hope this helps.
