Old Tue, July 14th, 2009, 03:35 PM
Corey, as I type this, it is 3:34PM in Gaw-Jah. And, it is almost midnight, 11:34PM in Dubai. So, an 8 hour time difference.
Old Tue, July 14th, 2009, 03:40 PM
mxriderae's Avatar
Go bigger !
yes you are absoloutly right !! it is 11,40 now
  #23
Old Fri, July 17th, 2009, 03:55 PM
mxriderae's Avatar
Go bigger !
Still waiting Bill
  #24
Old Sat, July 18th, 2009, 01:21 PM
mxriderae's Avatar
Go bigger !
I have a question .. should i have to connect the Gryphone to the truck while am trying to download the custom tunes ??
  #25
Old Sat, July 18th, 2009, 01:50 PM
No, you first set the tune back to Level 0 (stock) in your truck. Then remove the Gryphon. On your PC, start Pegasus and then connect your Gryphon to the PC through a USB cable. If your tunes are ready, you download them by clicking on Updates->Targeted Functions.
Once that all finishes, simply unplug the Gryphon from the PC, turn your truck's ignition to ON (but do not start it) and plug the Gryphon back in to the truck. Then, you can install your new custom tune.
Old Sat, July 18th, 2009, 02:46 PM
mxriderae's Avatar
Go bigger !
yes ,.. that`s what i did !!
but still the problem is there
  #27
Old Sat, July 18th, 2009, 09:38 PM
tohi2care's Avatar
tohi2care tohi2care is offline
Canadian
tohi2care is on a distinguished road
What error did you recieve?
<a href=http://i40.photobucket.com/albums/e202/tohi2care/ctmpphpLq00yA.jpg target=_blank>http://i40.photobucket.com/albums/e2...pphpLq00yA.jpg</a>
  #28
Old Sun, July 19th, 2009, 03:00 AM
tohi2care's Avatar
Canadian
Bill is under the impression that you have been taken care of. Please PM me with whatever problem you're still having so that it can be addressed because we must be missing something.
Here are the screen shots of my problems...
Last edited by Acidanthris; Sun, July 19th, 2009 at 05:41 PM. Reason: Cut out the part that wasn't helpful towards solving the problem.
  #29
Old Sun, July 19th, 2009, 03:53 AM
mxriderae's Avatar
Go bigger !
tohi2care .. the i had posted the massage befor .. this is it
  #30
Old Sun, July 19th, 2009, 05:48 PM
MX,
I am not sure where the problem is with the download.
Once again, please confirm that you are selecting [Updates] -> [Targeted Functions]. I know you have confirmed this previously, just want to make double sure.
At one point during the download (after the "Preparing Gryphon" and "Programming" status bars), you should see a Message Box that tells you to unplug the USB cable, reinsert the USB cable and then click [OK]. Are you getting to this point or does the download fail before you get the dialog? I just need to determine if the failure is during the transfer of the file to you from the server or if it is failing during the actual upload into the unit.
I'll be sitting here waiting for your reply.
Thanks.
