Old Sun, July 19th, 2009, 05:55 PM
Originally Posted by tohi2care View Post
Here are the screen shots of my problems...
The screen shots are a bit small to make out any details, but I can see that the serial number we have on recorddoes not match the one that is displayed in the software. I'm not sure what it is exactly, but it sure isn't 1311 which is what your download has been set for.
Please provide the correct serial number so we can get the download corrected.
  #32
Old Sun, July 19th, 2009, 05:58 PM
mxriderae's Avatar
Go bigger !
MX,
I am not sure where the problem is with the download.
Once again, please confirm that you are selecting [Updates] -> [Targeted Functions]. I know you have confirmed this previously, just want to make double sure.
At one point during the download (after the "Preparing Gryphon" and "Programming" status bars), you should see a Message Box that tells you to unplug the USB cable, reinsert the USB cable and then click [OK]. Are you getting to this point or does the download fail before you get the dialog? I just need to determine if the failure is during the transfer of the file to you from the server or if it failing during the actual upload into the unit.
I'll be sitting here waiting for your reply.
Thanks.
yes about the Updates - Targeted Functions yes
then those three msgs
  #33
Old Sun, July 19th, 2009, 05:59 PM
mxriderae's Avatar
Go bigger !
and about the msg box i don`t receive any thing
  #34
Old Sun, July 19th, 2009, 06:02 PM
From what I am reading, am I correct in assuming you never get a display box that says "Preparing Gryphon"?
This would indicate that the file may be damaged. I will rebuild the file and get back to you in a few minutes. Sit tight.
Thanks.
  #35
Old Sun, July 19th, 2009, 06:09 PM
mxriderae's Avatar
Go bigger !
now when i left it contected i got this msg
but not uploading
  #36
Old Sun, July 19th, 2009, 06:15 PM
I rebuilt the download. Try it again. If it fails I have some other options.
Standing by... :whistle:
  #37
Old Sun, July 19th, 2009, 06:17 PM
mxriderae's Avatar
Go bigger !
still the same
  #38
Old Sun, July 19th, 2009, 06:21 PM
mxriderae's Avatar
Go bigger !
i missed this one before
  #39
Old Sun, July 19th, 2009, 06:29 PM
Does that mean it worked?
Old Sun, July 19th, 2009, 06:30 PM
mxriderae's Avatar
Go bigger !
no it doesn`t !
