Old Mon, October 5th, 2009, 03:05 AM
blk99 blk99 is offline
blk99 is on a distinguished road
Default OD Light....
i have a question into Bill but i thought i would ask you guys too...
if i use my TC lock switch when the computer doesnt command it to be locked, the OD Light is suppose to flash, am i wrong? it does in stock but with the new tunes, it doesnt....
i have a few other issues, just waiting to hear about them
~Jim
Old Mon, October 5th, 2009, 05:39 AM
The only time the TC light should flash is if there is an issue with the trans or the converter that would otherwise set a DTC.
In other words, the TC light should NEVER flash. It should either be on or off depending on the switch selection.
Old Mon, October 5th, 2009, 02:00 PM
hmmm interesting....
i was always told that a TC lock switch would make the OD Light flash if you used it at times when the computer didnt want TC locked....
thank you
Old Mon, October 5th, 2009, 05:55 PM
I'm sorry... I misunderstood the question. You're referring to an "auxiliary" T/C switch. I took it to mean the standard O/D switch.
The T/C light might or might not blink depending on the calibration being used.
