Old Sun, March 22nd, 2009, 12:38 PM
average-joe average-joe is offline
Sex alleviates tension
average-joe is on a distinguished road
Originally Posted by Dragoon View Post
The trip meter gets wiped on a program? I am conidering picking up one of these units but I don't like that. I record my mileage and gas consumption religiously. And as forgetfull as I can be I would never remember to record it before a re-program.
The trip meter display does not get deleted on your truck.
Quality means doing it right when no one is looking.
  #12
Old Sun, March 22nd, 2009, 04:05 PM
You are absolutely right and I was wrong! Must be my rapidly fading brain cells! I was certain I saw the trip odometer get zeroed before, but, I just set the tune back to Level 0 (since I'm taking the truck to the dealer for some service) and, neither the trip odometer or Avg MPG figures were reset.
Old Mon, November 2nd, 2009, 01:48 PM
XPerties's Avatar
XPerties XPerties is offline
XPerties is on a distinguished road
I know this is an semi-old thread but prior to the Edge being upgraded to the Gryphon whenever I programmed hot or cold I never got any of the "check gauges" on my display. My Gryphon just came UPS today so I had to run around for a bit and when I was at the local 7-11 I programed to my custom tune and I got the "check gauges" displayed which did go away after the programming was done.
I've never seen this and it did cause some panic attack for a second.
Custom Gryphon Splash Screens
F150 05 5.4 XLT, Nitto 295/70/17, Dual Flowmaster, Gryphon w/ Custom Tunes
K&N CAI, HBS 2 1/2 Level Kit, Blackout Heads w/ 8K HID's, Tinted Tails & 3rd Light w/ LED's
  #14
Old Mon, November 2nd, 2009, 06:27 PM
It would give me a heart attack too! I've never seen a "check gauges" display, and don't really know what you're talking about. Is this something that came up on the dash gauges?
Maybe, just maybe, it's the sign of a weak battery? Weak batteries seem to be the cause of MANY programming problems.
  #15
Old Mon, November 2nd, 2009, 06:32 PM
XPerties's Avatar
Yes it was displayed on the dash LED display. Well my battery is the original and I'm in an 05 but my voltage is spot on and never had any major draws.
  #16
Old Mon, November 2nd, 2009, 06:53 PM
I replaced my OEM battery about a year ago. I would not trust yours at all, due to its age.
We had a LONG thread on batteries a while ago, you might look for it.
But, if you have a voltmeter, take a "resting voltage" reading of the battery after it's been sitting for several hours, preferably overnight. To do this properly, you want to open your hood the night before so the battery is exposed and you can get to it without opening doors which will activate electrical components.
If the resting voltage is in the neighborhood of 12.7 V or better, you are fully charged and I'd guess your battery is good. If it is below 12.4 V, I think your battery is on its last legs. Anything in between is grounds for a load test.
Old Mon, November 2nd, 2009, 07:57 PM
JWBFX4 JWBFX4 is offline
Well I figured I would chime in since I started this thread a while back....
Although since your truck is an 05 and the battery MIGHT be weak, IMHO I don't think thats the problem in this case.
Ever since I have started this thread and changed levels my truck has always said check gauges. Now mines an 06 with the original battery and I thought it could be a bad battery so I swapped in the battery out of my friends 08 and went to program and bamm the same thing happened. I think Sburn's post got the problem just right.
Because the oil pressure and the coolant temp gauge are the two not working (in my case) and I assume since it will not give a reading to the gauges during programming the truck thinks one of them are broke.
  #18
Old Mon, November 2nd, 2009, 11:34 PM
Living on borrowed time with that battery!
That's what I thought with mine also but I had a cat involved! Haha
only had 28K on that battery.
Maybe it makes a difference if they are DD or garage queens.
  #19
Old Tue, November 3rd, 2009, 05:19 PM
F-One-Fiddy F-One-Fiddy is offline
F-One-Fiddy is on a distinguished road
My 05' F150 FX4 will also display the "check gauges" during any programming and this display will remain until the PCM has been fully re-written. Then all is well. I agree with the idea that the gauges are not talking to each other during the programing. I have the edge, not gryphon.
Thanks,
