Old Sat, November 14th, 2009, 11:50 AM
loner1's Avatar
loner1 loner1 is offline
Don K.
loner1 is on a distinguished road
Daily Driver shifting?
How do you guys and gals like the shift points on your D.D. tune? When my transmission shifts into 3rd gear it goes right into t.c. lockup, the rest of the shift points are normal.Try as I may I just can't get to like it. I also have the stock setting, 25 tow and 40 tow, they all shift just super. I am really happy the way my tow tunes pull my 12,500# RV, no problems with the egt's, the engine pull nice and quiet compared to my other chip from a different tuner. To sum it all up, Bill did a fantastic as usual, I know he will get the shifting to my liking on the D.D. tune, I just would like your input on your D.D. tune. I am going to call him this coming week and work something out, maybe go with the performance tune instead of the D.D.
Thanks, Don
Old Sat, November 14th, 2009, 12:43 PM
What year is your truck and what was your PCM code before you installed the Phoenix?
Shift timing can be a bear because everyone's tastes are different, but since it's only one shift accompanied by the TCC apply, it won't be a big deal to fix. Depending on what Bill has done it can be fixed pretty easily in a few different ways.
With the 99.5-03 trucks my new best friend has become "Delay converter lock after 2-3".
Old Sat, November 14th, 2009, 03:28 PM
loner1's Avatar
Don K.
Cleatus12r, thanks for the quick reply. My truck is a 2003 F350 dually with 410 gears, the PCM is coded VDH5 but is was reflashed by a different tuner, I don't know what the original code was but is has always worked ok. I still have the original PCM that came with truck packed away. Hope this will help.
Don
Old Sat, November 14th, 2009, 05:40 PM
It's going to be a simple change of either a shift speed point or torque converter clutch apply speed.
The reason I wanted to know the PCM code was due to how the shift strategy is with a stock PCM. Ford did a lot of things with their seemingly endless array of box codes and every HEX code Ford programmed had something changed (they considered them upgrades but that is questionable depending on who you ask).
Good luck! I'll point Bill towards your concern and when he has a second I'm sure he'll be happy to address it.
Old Sat, November 14th, 2009, 06:38 PM
loner1's Avatar
Don K.
Thank's for all your help and concern about my shift point! I was going to call Bill this week but put it off until next week, but I now see Bill has his hands full at the present time. I can wait until the first part of December to call him, that won't be a problem for me I can still drive the truck, just need to get that tune tweaked sometime later when Bill gets caught up and is running with a full staff.
Thank's again: Don
Old Sat, November 14th, 2009, 07:40 PM
I wonder if that 2-3 TC delay would fix that weird shift I had way back when. Humm had not thought about that.. but that delay is a constant right? Regardless of load or APP etc.
ASE Master Auto Technician
2001 Ford Excursion 7.3 4x4
Old Sat, November 14th, 2009, 08:11 PM
I thought your issue was a 4-3 shift problem, DJ. That was a while ago so I could be mistaken.
Old Sun, November 15th, 2009, 01:42 AM
ChuckD's Avatar
ChuckD ChuckD is offline
Duty, Honor, Country
Mine is the same way. You can feel the TC lock up in 2nd and then depending on your throttle position its almost instant in 3rd. I can tell the delay but only at certain rpms and throttle position. I am very in tune with my truck so that may be why I can. I feel that it is done to help with towing and mpg's. I don't have a problem with it in mine but not to say someone else won't.
Chuck
1995 Mustang GT
2004 Explorer Limited
Old Sun, November 15th, 2009, 09:53 PM
That's what makes tuning for others kind of hard. What one person likes may not be what someone else is willing to tolerate or get used to.
Old Sun, November 15th, 2009, 10:23 PM
My thoughts exactly! I have personally got used to the way my truck behaves and got used to it, then programming changes and things are different. Hard to decide if there is someting wrong because thats not how it was before or is it intended for some reason.
