Old Fri, January 8th, 2010, 05:55 PM
zeuss zeuss is offline
zeuss is on a distinguished road
Well it smoked like heck til warm again. Pulling chip did nothing different, just took it out of equation. Next questonis could the glow plugs be bad even though they tested good for them. Not sure how they tested them.
2002 F250 CC A/T
33 BF Goodrich
Autometer Trans, Pyro & Boost on the pillar
Zoodad
PHP stock, 40,60,80,100, and whisper
Old Fri, January 8th, 2010, 07:07 PM
Usually glow plugs are only tested by putting a test light to the terminals. The clamp will go on the positive battery post and the pointy end of the light will go on the terminal for each glow plug. However, this test is pretty hit-or-miss and the proper way is to check the resistance.
My friend and I were bitten by the resistance check though about a month ago. All glow plugs tested good on a cold engine. Once current was supplied to the glow plugs though, some would go open (no continuity through them and hence no heat) and he would have a hard start and rough running once it started.
Old Fri, January 8th, 2010, 07:42 PM
So what is the best way to check them. I checked them at the plug after driving 50 miles. I hate to say it, but glow plugs are the only thing that makes sense to me for this much white smoke. If I pull them, is there a chance they might be shorter from being burned so much. Thanks so far and please keep helping. I in jam and need truck.
2002 F250 CC A/T
33 BF Goodrich
Zoodad
Old Sat, January 9th, 2010, 08:06 AM
They don't get "shorter". I don't mean to offend if I read that wrong.
I assume you meant "shorted". They do "wear" electrically which is the reason they don't last forever. Your truck has about 120K right? If they're the stock glow plugs (didn't read about a replacement in your original post) then I would definitely just do them because they have 120K on them.
I NEVER tell someone to throw money at something, but glow plugs are really important to the starting and first couple minutes of drivability so it's not a bad idea to do them at 120K miles. You might consider replacing the small harness under each valve cover while you're there.
Old Sat, January 9th, 2010, 09:04 AM
On some of the old trctors the tips would actually get shorter, thus reducing the area of heat on plug. And yes I am kinda ignorant about diesel stuff, so thanks for being kind to me. I am probably going to stick plugs in. Like I said, injectors just dont make logical sense to me, but plugs do.
2002 F250 CC A/T
33 BF Goodrich
Zoodad
Old Sat, January 9th, 2010, 03:53 PM
Well I changed the glow plugs out. The old ones all worked fine when I hooked them up to my battery charger. On the old ones only about one inch would light up compared to more on the new mtorcraft ones. Guess I will see in the morning. If you have any more ideas, please lay them out there. If the intake heater didn't work, would that cause the problem?
2002 F250 CC A/T
33 BF Goodrich
Zoodad
Old Sat, January 9th, 2010, 07:42 PM
Jeremy's Avatar
Jeremy Jeremy is offline
Spark Plug Inhibited
The truck never did this before, when started cold? This just started happening?
Another question? Does the smoking when first started only happens when it started cold? If the truck is plugged in does it still smoke? Also is it alot of smoke, or just a haze?
19 F-350 6.7 Auto
16 F-350 6.7 Auto
Old Sat, January 9th, 2010, 09:32 PM
Not sure about the poug inthing, but it dumps smoke like coal train, except white. I'm gonna try leaving the plugs on longer in the morning and see what happens then.
2002 F250 CC A/T
33 BF Goodrich
Zoodad
Old Sat, January 9th, 2010, 10:35 PM
Jeremy's Avatar
If you can plug it in tonight, let us know if it still smokes....
19 F-350 6.7 Auto
16 F-350 6.7 Auto
Old Sun, January 10th, 2010, 12:53 AM
Default testing glow plugs
I pulled glow plugs on my '94 a few years ago with 300k miles on it (i do not know if they were originals). I did the "test light" test and all eight made the light, light up bright.
I tested each glow plug with a 12 volt jump box and infrared thermometer 4 or 5 would get to about 200* and the others turned pink just at the tip, a new one will turn red for about on inch.
I think the best way to test is to take a 100 amp amp meter and hold it rite on to of the glow plug relay, connecting the relay studs to the studs on the amp meter and then you will see how many amps the glow plus pull. Use the meter on a new glow plug so you know how many amps 1 plug pulls
