Old Mon, February 22nd, 2010, 04:12 PM
cody994x4 cody994x4 is offline
texas offroading
cody994x4 is on a distinguished road
Default custom tunes for my gryphon
hello all, finally i will be ordering my gryphon sometime this week. i have a few simple questions before i order. i plan on using the gryphon all stock/canned until i get my custom tunes...i will just play around w how to use the programmer and go through menus/options but not change anything, i just want to familiarize myself w the interface and get used to it.
as far as my tunes im gonna go with 87perf and 91/93 perf.
im not sure if i will need a custom tow tune, i tow rarely and when i do its no more than 3k lbs, usually just a pop-up camper, the hardest pulling i do is through colorado mountains but that is once a yr to go hunting, do i need a custom tune for this?
when i get my level one and three tunes, will my tire size/new gear ratio be dialed in? will i have to manually enter anything?
also, when i order i wont have my hex code right? ill get that once i receive my gryphon?
looking forward to this as ive wanted one forever.
Old Mon, February 22nd, 2010, 05:58 PM
You didn't say if you had any mods dependent on custom tunes?
The other thing is performance tunes have a max of 2500lbs for towing.
So if you have mods dependent on custom tunes then get a custom tow tune.
Your will want to find a sticky in gryphon programmers that I wrote up about hex codes and what to do with them after you get the gryphon.
Old Tue, February 23rd, 2010, 11:30 AM
And Cody - You see your HEX code on the Gryphon's screen the first time you plug it in to your truck.
Old Tue, February 23rd, 2010, 02:03 PM
texas offroading
the only mods i have rt now are a muffler only exhaust si/do and 33"tires, does this mean i need 3 custom tunes? and will the tire/gear ratio be included in the custom files or is that something ill need to do myself? i think the tire size is entered in mm's, is this correct?
thankx
Old Tue, February 23rd, 2010, 03:50 PM
thankx
You dont really need a custom tune for those. What you can do is buy a custom 87 and custom 93 performance and keep the canned tow. The only tune that you would need to adjust the tire size would be the canned tow.
