| 2004 to 2008 F-150 and Mark-LT 4.2L, 4.6L and 5.4L equipped F-150s and Mark-LTs. |
#11
Out of 107 sensors returned: 65 functioning properly, 19 completely dead, 23 malfunctioning. Of the 23 malfunctioning, none had any evidence of k&n oil. Mass Air Flow Sensors Intro & Test Results Summary Test bench: 1000 CFM for 3 days straight using a 30% over-oiled filter = No oil loss from filter. Can Oil Come Off Our Filters? High Airflow Testing & Engine Air Filter Dynamics Dunking the MAF in a beaker of oil, initial readings were off, but sensor returned to normal operation after a few cycles. What Does It Take to Foul a MAF Sensor? Extreme Testing I think this myth is what Adam and Jamie would call: BUSTED!
2008 F150 XLT SCrew 5.4L FFV 4x4 3.73LS 5.5' Chrome Pkg, Edge Evo (out to PHP), K&N 63, Custom mounted Troyer Performance E-fans, Truxedo Lo-Pro cover, Line-X bedliner, Passport 8500 X50 |
#12
I'm not saying you or K&N are wrong.
Also like I said, when I installed my drop in filter I did notice an instant improvement so they do have a good product. I have no problem with oiled filters because I've been using them for years on everything from gocarts and motorcycles to large diesel tractors and havent had a problem with them yet.
Also their tests are biased due to that they performed them and did not have third party intervention. I challenge you to find third party testing before you announce BUSTED!
SENIOR MODERATOR--PTLA God doesn't have a Facebook but he's my friend. God doesn't have a twitter, but I follow him. |
#14
#15
Uh, I don't think so. At least it wouldn't be that way on my truck. If I understand a drop in filter correctly, it just replaces the OEM paper one and that thing is upstream of the MAF.
However, I agree it would be nice for K&N to have an independent lab do the testing. Regardless though, I liked the "tone" of what I read so far. No wild claims and no emotional tirades. - Jack |
#16
Yes you are correct, I ran out and looked.
#17
I'm delighted that I'm not the only one to make dumb posts now and then! I was starting to feel like an idiot after my questions in the Moderator's forum.
![]() - Jack |
#18
#19
![]() Why would the car brand make any difference? The same K&N filter technology & same oil is used on all their filters... Quote:
What about the millions of other filters they have sold over the years? Just think of how many millions of miles have been driven with their filters? How more unbiased a study do you want? I have a technical background, I work in a lab, and I do a lot of testing according to standards. So I can appreciate when a company spends the time to do the R&D, with a dedicated test fixture, with annually calibrated instruments. You won't even find that at Mythbusters... This myth is busted, IMO
2008 F150 XLT SCrew 5.4L FFV 4x4 3.73LS 5.5' Chrome Pkg, Edge Evo (out to PHP), K&N 63, Custom mounted Troyer Performance E-fans, Truxedo Lo-Pro cover, Line-X bedliner, Passport 8500 X50 Last edited by Keeblerz28; Tue, April 20th, 2010 at 01:11 AM. |
#20
I think the point being made is that K&N was the party that was handling the testing (at least as far as which "independent" company handled the testing) as well as handling the information on their results. With this in mind, it's possible (although I'd hope unlikely) that they could intentionally obfuscate the facts in their favor. I think it would be more credible if a fully independent test, of which K&N had no control whatsoever, was done. Quote:
For example: A few years ago, Ford was reflashing 6.0L trucks with updated ECM/TCM/FICM strategies and IMMEDIATELY (as in before they even left the parking lot) customers noticed a loss of performance and subsequently noticed losses in fuel economy. Ford, in response to these complaints, did study of these complaints and this was what they had found: http://www.gopowerhungry.com/Downloads/6.0L Fuel Economy Test.pdf Apparently, it's Ford's opinion that there is no problem with the updated strategies and that all the customers that have lost performance and fuel economy must be suffering from some sort of mass delusion. Just because the manufacturer claims it, doesn't make it so. ![]() For what it's worth, I have PERSONALLY removed MAF sensors from vehicles that had oil residue on and in the units, not to mention all down the intake tubes. This would be, presumably, from improper/over oiling of the filter element. While the sensors hadn't "failed" per se, the oil coating the sensor wires would cause delayed response of the sensor by insulating the thermal transfer across the sensing element. This would result in backfiring, throttle hesitation, and minor drivability issues. A simple cleaning with electronics cleaner and the residue was removed and the drivability symptoms would clear right up. Based on K&N's testing though, I must be crazy to think their filter had anything to do with the problems. One final thought... We always enjoy in partaking of a hearty, and sometimes even heated, discussion on a variety of subjects. However, our forum is based on the respect of other members, and as such, insults will not be tolerated. Calling someone's arguments or opinions "pathetic" is not only unacceptable, it's not conducive to argument/debate process. If that type of behavior continues, the consequences will be swift and severe. Keep it respectful, and we'll all get along just fine. Take care.
Bill Cohron - The Mad Doctor ![]() Power Hungry Performance - The ORIGINAL in Ford performance tuning... Since 1997! (678) 890-1110 www.gopowerhungry.com - Home of the Hydra Chip, Minotaur Tuning Software, and the new Orion Reflash System for Navistar! Bring back Windows™ XP and 7. Windows™ Vista and Windows™ 8 is a pain in my a$$! ![]() Windows™ 10 is only slightly less annoying! ![]() Windows™ 11 is garbage! ![]() Much to my surprise, I'm actually quite enjoying Linux!
